I have been searching for 2 pin connectors that can be used for connecting to the pins of L.E.D's . I've been using the plug from old phone battery connectors by simply soldering some additional length. Any other simple ideas?
i use large intergrated circuit sockets for pluging parts into like scr as in my scr tester and i use the the pins from the other type of intergrated circuit socket as matrix pins to solder wires to rarether than the board, with the large ic sockets i cut them down to say 3 for scr tester or 4 if i needed more leg spaceing
theres a few transister sockets out ones for the power transister and i use them and you can plug leds into them to, and theres 2 other ones which i got from dismantleing junk for parts like old tvs, you may find one, in them if your lucky
