Stupid op-amp question
darrins
Jun 29, 2004
82
I'm trying to amplify the voltage DIFFERENCE between two inputs. One input (V2) is a reference voltage of about 1 volt. The other input (V1) is from a heat sensor that is fairly linear at 0.1 volt per degree Fahrenheit. So, for my application, the input from the heat sensor is about 0.7 volt.
I'm using 1/4 of a quad op-amp (LM324).
I've wired the op-amp as a differential amplifier, like this:
I'd like the gain to be 22, so I'm using 2, 220K resistors -- one between the output and the inverting input (feeback) and one between the non-inverting input and ground. I'm using 10K resistors in between my inputs (V1 and V2) and the op-amp inputs.
If my math is correct, I should have a gain of 22. For my example of V1=0.7V and V2 = 1V, the output should measure 6.6V, but when I use my voltmeter, I'm only reading about 1 Volt. ???
Any suggestions?
Is it possible that my quad op-amp is damaged? If so, is there a way to test it?
By the way, I grounded all the pins on the quad op-amp that I wasn't using.
Thanks for any advice. :)
Darrin
audioguru2
Apr 6, 2004
12,026
Hi Darrins,
You don't need the "common-mode balancing resistors" that are the voltage divider resistors at the non-inverting input for V2. With those resistors then the reference voltage isn't exactly 1.0V. Just connect the non-inverting input directly to the reference.
I suspect that your lack of gain is because the sensor's impedance is not low, so it adds to the input resistor, reducing gain.
Please post your sensor circuit to see, and because I am curious at how it produces the high voltage change of 0.1V/degree F.
With the sensor at 0.7V, the output will be 7.66V, not 6.66V, because the reference voltage adds to the output voltage.
Don't ground the outputs of the opamps that you are not using, just ground the inputs and let the outputs set their own voltage level.
Better yet, connect them as followers with 100% negative feedback and the non-inverting inputs grounded, to avoid the outputs wildly swinging with noise.
darrins
Jun 29, 2004
82
Thanks audioguru.
Actually, there's a typo in my original post. The output from the heat sensor (http://www.national.com/ds/LM/LM34.pdf) is 10 mV/deg F.
When you said that I don't need the "common-mode balancing resistors", are you referring to BOTH resistors connected to the non-inverting input?
I'll try your recommendation of wiring the unused op-amps as voltage followers with non-invert inputs grounded.
I'm still somewhat confused why a circuit that is in several of my textbooks doesn't function "as advertised".
Thanks again for your help.
Darrin
audioguru2
Apr 6, 2004
12,026
Hi Darrin,
You don't need any resistor on the non-inverting input of your difference opamp. Just connect it directly to the reference voltage.
On the datasheet, only one application hinted at using a high-impedance load for the sensor, and yours is a fairly low 10K ohms. Most applications show it sourcing a voltage, for example the analog meter that is referenced to ground. Your difference circuit has it sinking current from your opamp's 10K input resistor. The first page mentions a 0.4 ohm output impedance but only with a 1mA load to a negative voltage. Surely that 1mA will cause it to self-heat and change its temperature measurement somewhat.
You can convert your difference opamp circuit into a high impedance load by buffering its 10K input with one of your spare voltage followers, with the follower's input lightly loading the sensor's output. Then your circuit will work "as advertised".
darrins
Jun 29, 2004
82
Thanks audioguru.
I think I found something similar to what you are talking about.
High Input Z, DC Differential Amplifier (p. 15 on this datasheet)
http://www.national.com/ds/LM/LM124.pdf
Thanks again.
Darrin
Kevin Weddle
Feb 23, 2004
1,620
Try using the recommended load of 10kohms to the negative supply. Apply the 1 volt to the noninverting input directly. Then apply the .7v to the inverting input through the 10k. The voltage on the output will be 3V.
audioguru2
Apr 6, 2004
12,026
Hi Darrin,
You don't need the high Common Mode Rejection Ratio (same interfering signal that occurs on both inputs that are driven from perhaps a long unshielded pair of wires) of that high impedance circuit. A simple follower driving your 10K inverting-input resistor will be fine and allow for an easy gain calculation.
Hi Kevin,
Your idea will work only if the resistor that is connected to a negative supply has a current that is greater than the current that is being pulled-up by the opamp's 10K input resistor.
I think that Darrin doesn't have, and is trying to avoid using, a negative supply.
I don't see how the opamp, with a 0.3V signal to amplify with a gain of 22 plus the 1.0V reference, will have an output voltage of only 3.0V. It will be 0.3 X 22 = 6.6 + 1.0 = 7.6V.
Kevin Weddle
Feb 23, 2004
1,620
He is applying the .7v through the 10kohm resistor which will make the input .86v. 1-.86 x 22=3v.
audioguru2
Apr 6, 2004
12,026
No Kevin,
You must realise that because an opamp has such a high open-loop voltage gain of 100,000 or more, its inverting and non-inverting pins' voltages are virtually the same when negative feedback is applied.
The input voltage of 0.7V pulls-down on the 10K input resistor, creating 0.3V across it and therefore 30microamps through it. The opamp maintains the inverting input pin to be the same voltage as the non-inverting input pin (1.0V reference) by increasing its output voltage so that the current through its feedback resistor equals the current through its input resistor. Therefore 30 microamps through the 220K feedback resistor makes the opamp's output 6.6V higher than the reference voltage. Try it and see.
GPG1
May 3, 2004
71
if my math is correct, I should have a gain of 22. For my example of V1=0.7V and V2 = 1V, the output should measure 6.6V,
Correct
audioguru2
Apr 6, 2004
12,026
Sorry GPG,
As I said before, the output won't be 6.6V, but will actually be 6.6V above the 1.0V reference voltage, so the output voltage will be 7.6V.
GPG1
May 3, 2004
71
In his original circuit, the output will be 6.6V It only goes to 7.6 volts in your modified design. There is nothing wrong with the original design that requires modification, and it provides much better common mde rejection since the gain from both inputs is equal.
audioguru2
Apr 6, 2004
12,026
Hi GPG,
You are absolutely right!
I am the one who is stupid, because I thought that 0.05V drop in the original diff-amp was negligible, but it's not when it is amplified with a gain of 22. When I added numbers to the schematic, I realised my error:
MP1
Dec 7, 2003
3,399
GPG, good of you to notice. Audioguru strikes again with redesign of something that already works... I am sure there will be more to come...
MP
audioguru2
Apr 6, 2004
12,026
I've wired the op-amp as a differential amplifier.
Any suggestions?
Darrin
MP,
His differential amp doesnt work, that's why he started this post.
It fails probably because the inverting input of it has a resistance that is too low for his sensor to drive, so I simply suggested using his spare opamp to buffer it.
What is your fix for his problem?
GPG1
May 3, 2004
71
Previous post
gain of 22.
Gain of 23
The sensor is easily able to drive a 10K load. The amp is probably stuffed through shorting the outputs.
audioguru2
Apr 6, 2004
12,026
Hi GPG,
1) The gain of this diff amp depends on what you call its input.
The entire circuit has a differential gain from between the inputs, V1 and V2, of exactly 22 (not 23).
An input from the inverting input, V1, to ground has a gain of exactly 22.
An input from the non-inverting input, V2, to ground also has a gain of exactly 22.
Only an input from the non-inverting point, V3, to ground has a gain of 23.
2) The LM34 has an NPN emitter-follower with resistors-to-ground output. At 0 degrees F, the entire IC (excluding its emitter-follower which will have 0V output) has a quiescent current of 60uA.
Its increase in quiescent current of only 15uA at 75 degrees F occurs only in its emitter resistors, which will have 0.75V across them, and therefore calculate to total 50K ohms. Any sourcing load will cause enormous inaccuracy.
Therefore it is not capable of sinking any current from a load that has a positive voltage source like our diff amp that sources 25uA.
It can source a current to a grounded load like an analog meter, or drive a high impedance load.
Darrin's results will confirm it.
GPG1
May 3, 2004
71
~43.5mV, 23 gain
Reference please
Reference please
Capable of doing so down to 5
