Hi Suraj,
Thanks for the Navy link with its very good illustrations.
But even those Navy folks got the theory wrong when they say, "The process of demodulation usually involves detecting the envelope of the AM signal. This may easily be accomplished by using a low-frequency filter (like a capacitor) which will remove the quickly oscillating carrier signal, leaving only the slowly-varying amplitude".
You can't recover the symmetrical amplitude variations with just a filter, without using a rectifier so that the waveform isn't symmetrical anymore and therefore the amplitude variations can be recovered.
I've had enough of old lousy-sounding, interference-prone AM radio.
I like FM radio but wish the broadcasters would reduce the compression and limiting of the audio. If the listeners at the far away fringes of reception get some noise, they can just use a bigger, higher antenna or move closer! ;D
Even the FM sound on TV broadcasts is pretty good nowadays.
I wish the TV announcers would stop hiding the microphone down on their clothes and put it in front of their mouth where it belongs.
Have you ever heard the poor quality of an underwater throat mic?
Lavalier mics sound similar. A lavalier mic picks-up the fundamental chest vibrations very loudly and the compressor cuts the volume down to normal, severely reducing the volume of the harmonics, "s" and "t" and other important sounds of speech. Have you ever seen (heard) a singer use a lavalier mic? No way, man! ;D
