electronic valve shower, do you have an idea???
jeffjavier
Oct 5, 2004
9
hi,
do you have an idea on building up an electronic shower valve in which it can be controlled using a switch, this is my problem in my plants watering system.
ante1
Jan 24, 2004
4,138
Hi Jeff,
Do you just need a circuit to open and shut an electric valve or should there be some kind of sensor to control the valve?
Y
Yevgenip
Jan 1, 1970
About the mechanical bit, you should use eather two electromagnets or a motor to close and open the valve.
EnigmaOne
Jan 2, 2005
101
Hmmmm....I'm thinking that a simple, 24VDC, solenoid-operated, irrigation (sprinkler) valve body and head would be the exact thing you're looking for.
[added]
After some thought, you might also get away with using a solenoid-controlled valve for a refrigerator/freezer icemaker sub-assembly...probably quite a bit cheaper, although it will be operated by mains voltage.
In that case, you could swap-out the coil for a low-voltage coil, or use a SSR to switch the mains voltage to the solenoid coil.
ante1
Jan 24, 2004
4,138
You can control a mains powered valve via a small relay, or a triac and an optoisolator.
There are some nice solenoid valves to be scavenged in scraped washing machines and dishwashers .
EnigmaOne
Jan 2, 2005
101
In that vein, this type of thing is probably what you're after:
http://www.pcappliancerepair.com/dwash-ge.shtml#wiv (top valve)
EnigmaOne
Jan 2, 2005
101
Yup, but the best way to get one is from the junkyard...much more economical that way. ;)
Y
Yevgenip
Jan 1, 1970
If you think about it, people can live their whole lifes in junkyards without ever being hungry or poor.
GreekPIC
Aug 1, 2004
251
If you're still interested, a good place to find solenoid valves is a washing machine. I dismantled one that someone threw away (it was in perfect condition, just old). I took several usefull parts out of it.
audioguru2
Apr 6, 2004
12,026
What a lousy life that would be. What about internet?
I guess they could get shelter in a discarded washing machine. ;D
EdwardM
Apr 12, 2005
246
Hi
from:audioguru I guess they could get shelter in a discarded washing machine.
better yet, join lots together to make a condo, rent it out (internet now possible)
Hey it's saturday, wind-down time  ;D
Ed
rybitski
Jan 9, 2006
161
as long as your junk yard is near a building or something that has wi-fi then you are set... free internet and cheap property tax.  ;D
