Pb-free soldering
STEVE2
Jan 5, 2004
59
I don't think that anyone has started a topic on this as far as I can see ...
I was just wondering whether anyone had any experience with using lead-free solder yet?
There have been various directives put forward by the European parliament, such as the RoHS (Restriction of certain Hazardous Substances) and WEEE (Waste in Electronics and Electrical Equipment). Basically the lead content in solder is to be reduced to something around 0.1% (current solder contains about 60%).
I have done a little research into the area before but only really on the industrial implications and I'd be interested to see if any of the problems found in industry are such big problems on a smaller scale ...
Let me know if you have had any experiences
Thanks :D
trigger
Aug 7, 2004
236
What I know is, the soldering temperature need to be higher (or time longer) and this may bring problems to some components with poor thermal resistant.
STEVE2
Jan 5, 2004
59
I thought I would post the implications of Pb-free soldering I have found on an industrial scale. This is more for interests sake but also to see if anyone has found similar attributes in a more 'domestic' setting.
Issues which can arise are: the flux used; corrosion of equipment; higher soldering temperature considerations (on components, and in industry board sagging) and fillet lifting.
Dependant on the composition of the Pb-free solder the flux may have to be changed to a water or chloride based flux. This new flux can start to corrode the boards after a while if it isn't cleaned off (hot water can clean it off - just make sure you haven't got the board powered up when you clean it!! :eek:).
Another effect the new solders can have is they can corrode stainless steel. I don't think this would have much effect in the 'domestic' setting, in industry some of the equipment used for wave soldering etc. contain stainless steel parts.
You may have to be careful about raising the temperature too high on your soldering iron incase it starts to damage IC's etc.. In industry they also have to be careful about how high a temperature the boards are heated because they start to sag - too much sag can be bad news.
Fillet lifting is another concern when using the new solder. If you want me to explain what fillet lifting is let me know. Ways to reduce it include: Avoid the use of BISMUTH (Bi) containing alloys; Avoid lead contamination into lead-free alternatives; Increase the cooling rate immediately after soldering.
Like I have said I have only really researched into the industrial implications of Pb-free soldering and I have no experience in the effects for 'domestic' soldering. I'd be very interested to know if anyone comes across any of the problems I have mentioned above.
Thanks ;D
audioguru2
Apr 6, 2004
12,026
I have heard that if PB-free solder mixes with PB solder it makes a terrible mess. In the future, how will a technician or hobbiest know which one to use?
STEVE2
Jan 5, 2004
59
I'm haven't seen the affects at first hand of what happens when the two solders are cross-contaminated, but perhaps there won't be much chance of this happening as everyone will have to use lead-free solder and Pb solder will become obselete ???
trigger
Aug 7, 2004
236
oh.... if the Pb solder and Pb-free solder will mess up, the most problem would be happened to supporting engineers/technicians.........
Shops now still selling Pb solder... at least for me, I still got 2 big roll at home........ >:(
audioguru2
Apr 6, 2004
12,026
Yeah, soon you won't be able to buy it anymore, then the police will be raiding technicians homes, so hide your good PB solder!
A
Alun
Jan 1, 1970
I'm not too bothered I have a big enough stash of Pb solder to keep me supplied for many years ;D
And what about batteries?
audioguru2
Apr 6, 2004
12,026
Hi Alun,
Battery companies like Eveready don't make Ni-Cad's anymore. They have similar and with much more capacity Ni-MH ones now.
MP1
Dec 7, 2003
3,399
I buy bars of solder since I use a large quantity in my facility. I wonder if the obsolete bars will gain value like gold. ;D
MP
audioguru2
Apr 6, 2004
12,026
Only if they look pretty when made into jewellry and don't corrode. ;D
Miles Prower
Apr 27, 2005
28
Yeah, I tried that lead free solder. I didn't like that at all. While it may be a good idea so far as soldering water lines, it SUX for soldering electronics. Takes too long to melt, too prone to making cold joints, overheats sensitive components. Unless you have a habit of licking your circuit boards, I don't see the point.
audioguru2
Apr 6, 2004
12,026
The beaurocrats are worried about lead contaminated circuit boards littering everywhere like gum wrappers. Haven't you seen how many people discard circuit boards on streets and sidewalks? ;D
A
Alun
Jan 1, 1970
There's still the probelm of discarded electronis on the dump contaminating the ground water. We're currently phasing out lead solder as it will be banned soon. The company I work at won't be affected as we work on MOD contracts I don't think they're bothered about circuit boards on bombs containning lead solder. ;D
Cerium
Aug 10, 2005
18
They should be.  You dont want vaporized lead do you? lol
I have used pb-free solder. It works but does take longer to melt. It costs a lot more. I got a 1lb. roll of pb solder for like $6 and a small tube of pb-free cost $4.5 if I remember right.
Similar threads
H
Replies
39
4K
TheGlimmerMan
T
C
Replies
1
1K
Rene Tschaggelar
R
G
Replies
4
1K
Mark Harriss
M
S
Replies
12
2K
Ken Smith
K
