Hi All,
I need a simple circuit that will light an LED when contacts of a micro switch open. The switch is in series with a gas valve which operates on 24vac. In the "normal" operating state, the switch is closed and the gas valve is allowed to operate. When air flow is low, the switch opens taking power away from the gas valve which will then shut off. The switch only has two connections and it has to be as simple as possible. I want the LED to come on when the switch opens to let operators know the heat is off.
Any ideas on a simple circuit would be apprecated!
Thanks in advance,
Robert
Thanks in advance,
Robert
