Ok, go to an electronics supplier, radio shack will do for a beginner, and buy a variety of resistors, solder, a pencil soldering iron, a pack of 9v batteries, a 9volt connector (you know, pad thingy with male and female terminals and red and black wire sticking out. Matter of fact, buy two or three of them) Get some aligator clips if they have them, a roll of 18 AWG wire, and a cheap multimeter (volts,ohms,amps). All of this shouldn't cost more than 40 bucks and most of it will last a long time and through a lot of experimenting.
Now, Here is an important formula for you to memorize if you don't already know it: Ohm's Law states E=IxR (e=voltage, I=current or Amps, R=resistance.)
Google this topic or read about it on the forum. You HAVE to know this to understand electronics or anything electrical, including your home wiring.
Also, Google and read about Series and Parallel Circuit arrangements. If you don't already know it, learn the difference between AC and DC, which can all be found on the internet.
The rest is up to you in this experiment. I am going to post a drawing showing how to wire batteries up in parallel and in series, and how to connect a LOAD (important term) to the battery in series and in parallel. This is exactly where you need to start. If you are already past this stage, ignore this post and let us know more. You can print this file and try this experiment!
