0-99 Binary to BCD converter
My prof assigned me a bonus project to try out. We current built a
basic Binary display using 4 switches and the 7447 convert to light up
a seven segment display. The challenge is to build a counter that will
take 7 input binary, for 0-99 and display it with two seven segment
displays on a digital board. I need to figure out a way to build this
using IC chips. Now I'm not looking for the answer in plain English
hints would be nice. He suggest using a full adder but when looking at
this I cannot seem to find a way to use it. I started to configure a
set up but its starting to use way to many chips, and it seems like I
am just making inputs for every number from 0-99.
any assistance is greatly appreciated.
DJ Delorie
Well, you can do it in one chip if you're allowed to use a
microcontroller ;-)
Gilles Kohl
Less horsepower than that. (E)PROM look up table. Too bad this isn't
allowed either.
Wouldn't you need a counter in addition to the (E)PROM? (Making it two
chips)
Regards,
Gilles.
jasen
the lowest bit will be easy after that it gets interesting.
one way would be a 128 byte rom :)
I see two possible approaches,
one is massed logic, just figure out how each output bit is determines by
the input bits..
the other is synchronised counters, drive two counters one that counts base 10
and drives the display and another that counts in bibary and you compare
with the input.
or even better a presettable binary down counter, and a two-digit BCD up
counter.
look up these (cmos 4000 family) part numbers. 4553 4516 4518 4029
download the datasheets and see what you can do.
eg type "4553 datasheet" in the google search box and see where
it takes you.
Bye.
Jasen
Bob Masta
Sound like your prof is playing a trick on you. (Did
you get this assignment on April 1?)
The conventional approach (way back when people
actually did these things with discrete chips) is to use decade
counters, such as the 7490, which can be cascaded
to count as many digits as you like. Each 7490 sends
its output to one 7447. No adders needed!
Best regards,
Bob Masta
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Signal Generator
Science with your sound card!
John Fields
The brute force way is to load the seven bit binary number into a
binary down-counter and at the same time to clear two BCD counters
connected in cascade. Then clock them both with the same clock and
stop counting when the binary counter gets to zero. The BCD
counters will now have as outputs the BCD value of the binary number
loaded into the down-counter.
DJ Delorie
chips)
Nope. seven address bits, eight data bits - the address is the "input
value" and the resulting data is the pre-computed BCD-decoded value.
You could even pre-compute the 7-segment decode, with seven address
bits and 14 data bits.
F
feebo
really? Is this the way you'd do it?
Why wouldn't you use a couple of 74LS185 to do direct conversion?
F
feebo
sorry - link...
http://www.alldatasheet.com/datasheet-pdf/pdf/98237/TI/74185.html
F
feebo
lots of answers from other people here (mostly jokes, right?)... but..
the best way to do it is with 2x 74LS185 - they are designed exactly
for this job.
Forget about counters and stuff, these two chips correctly arranged
will provide the correct BCD outputs to feed into your 7447s - i.e
exactly what you want.
petrus bitbyter
One thing is not clear to me: Do you have a 7-bits binary counter (so you
need to convert from binary to BCD to 7-segment) or do you need a BCD
counter that outputs directly in 7-segment? Or even some other scheme?
As for using full adders for conversion, suppose "In" to be the binary input
and "Out" to be the BCD output, you get:
In<=9 Out=In+0
10<=In<=19 Out=In+6
20<=In<=29 Out=In+12
30<=In<=39 Out=In+18
90<=In<=99 Out=In+54
Straight forward decoding this way requires ten full adders and ten
comparators plus still two 7447, which makes a total of 42 ICs. Don't think
this way of decoding will ever become popular. I've done similar decoding
using an EPROM and two 7447. The "normal" old way was using BCD-counters and
7447. No need to say all this stuff is packed in one micro this days.
petrus bitbyter
DJ Delorie
for this job.
The 74LS185 is a ROM chip, pre-programmed with the results. This is
one of the "joke" solutions you refer to.
Anthony Fremont
feebo said:
oops... 3x 74ls185, not two - soz
You were correct the first time, it only takes 2x to do the numbers 0 - 99
with a 7 bit binary input. Good luck finding a supplier, I could hardly
find a datasheet. ;-)
F
feebo
blimey! you are right - rare as chicken thingies.
F
feebo
thanks to everyones input, Eproms I don't know how to use and I'm
almost certain 74Is185 have been discontinued.
doing it with an eprom is quite easy and, Ithink, the best option.
eproms work by you providing a binary address (i.e. what you are
currently providing to you 7447 and giving out a piece of data (8 bits
- just right to feed 2x 7447)
you will need to make sure that whatever eprom you use, you ensure the
CS is low and the output (OE or RD) on some is also enabled all the
time.
then you need to work out what combination of data patterns comes
out... here is a list of the data for each address... assuming you are
driving two 7447, the Left most digit driven from the least
significant 4 bits (D0 - D3)
all addresses and data are in HEX.
connect your 7 bits of data to A0-A6 and connect all other address
lines to 0V
should have this up and running is 2 hours max - assuming you have
access to an EPROM programmer
significant 4 bits (D0 - D3)... Not really my habit to spoon feed, but
trust me - this will lead to greater things once your creative juices
start flowing.
ADDR DAT
0000 00
0001 01
0002 02
0003 03
0004 04
0005 05
0006 06
0007 07
0008 08
0009 09
000A 10
000B 11
000C 12
000D 13
000E 14
000F 15
0010 16
0011 17
0012 18
0013 19
0014 20
0015 21
0016 22
0017 23
0018 24
0019 25
001A 26
001B 27
001C 28
001D 29
001E 30
001F 31
0020 32
0021 33
0022 34
0023 35
0024 36
0025 37
0026 38
0027 39
0028 40
0029 41
002A 42
002B 43
002C 44
002D 45
002E 46
002F 47
0030 48
0031 49
0032 50
0033 51
0034 52
0035 53
0036 54
0037 55
0038 56
0039 57
003A 58
003B 59
003C 60
003D 61
003E 62
003F 63
0040 64
0041 65
0042 66
0043 67
0044 68
0045 69
0046 70
0047 71
0048 72
0049 73
004A 74
004B 75
004C 76
004D 77
004E 78
004F 79
0050 80
0051 81
0052 82
0053 83
0054 84
0055 85
0056 86
0057 87
0058 88
0059 89
005A 90
005B 91
005C 92
005D 93
005E 94
005F 95
0060 96
0061 97
0062 98
0063 99
0064 FF
0065 FF
0066 FF
0067 FF
0068 FF
0069 FF
006A FF
006B FF
006C FF
006D FF
006E FF
006F FF
0070 FF
0071 FF
0072 FF
0073 FF
0074 FF
0075 FF
0076 FF
0077 FF
0078 FF
0079 FF
007A FF
007B FF
007C FF
007D FF
007E FF
007F FF
F
feebo
instead of doubling up your eproms (or using a big beastie)
why not just use A7 as a strobe and provide both seven seg data on the
single data outputs.
so use A7 to toggle between display segments
F
feebo
what? a two chip "discrete TTL" solution to do exactly what the OP
wants - fail to see the joke. The internal construction of the chip
has no bearing...
