100v (japanese) to 120v (usa) on a capacitor motor
hey smart people,
i have a japanese fan that i want to install in my attic on
thermostat. its from a clean room in japan, running on 100v. ive heard
that i can do this without a transformer, "it will just run hot".
is this true? is there a chance of fire? just how hot? will it likely
smoke in a week? or a year?
thank you
Mike Berger
That could be a significant overload. Use a transformer or maybe
a light bulb in series. It's not unusual to see 127 volts on the
lines here. Unless there's something very special about the fan
I wouldn't bother.
H
Homer J Simpson
Is the fan 50 or 60 cycle?
Sam Goldwasser
I wouldn't bother.
Get a power transformer with a ~20 V secondary rated for the current of
the fan. Then wire the primary across the line, secondary in series with
the fan with reverse polarity. You can probably find a suitable transformer
on eBay.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
James Sweet
hey smart people,
thank you
I would use a transformer. It can be done cheaply by wiring up a 120V to
24V power transformer in a buck configuration. You can get one of these
cheaply from anywhere that sells HVAC surplus. Just make sure the
secondary is rated to handle as much current as the motor draws, it does
not have to be a very big transformer because it is not powering the
full load of the fan.
