10BASE-T Clock Recovery PLL
martin griffith
See http://www.holmea.demon.co.uk/Ethernet/EthernetRx.htm for photos,
docs and schematics of a (just for fun) experimental 10BASE-T receiver
project. It's locking too slowly at the moment. Comments / advice /
suggestions welcome.
Regards,
Andrew.
Thanks Andrew
Thats just what i wanted, line drivers for CAT5 cable, but hadn't got
around to googling yet!
I'm not using it for ethernet, just loads of digital audio!
martin
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
Mike
I don't think your problem is with your charge pump transistors.
I'm assuming the upper trace in your scope photo is your loop filter
voltage. If it is, then you have at least two problems.
1. At the start of the preamble, the voltage on your loop filter is hitting
its limit. As soon as it limits, the loop response is no longer linear.
2. At the end of the data, the loop is losing lock when it hits the
checksum. If it loses lock at the checksum, it will lose lock when you
replace the 0x55 data with real data. Your phase detector is supposed to
handle nonuniform data, but it looks as though it's not.
I have two suggestions:
1. Since you've got some programming experience, why not write a
time-domain simulator for your PLL? It's not that difficult, and with your
C++ knowledge, you can create classes for the phase detector, charge pump,
loop filter, and VCO. Adding nonlinearities is relatively easy, so you can
include saturation effects and such. Start with ideal models for the logic
and loop filter, and spend your time creating more detailed models for the
charge pump and VCO.
2. There is an initial frequency offset in your system which your step
response is ignoring. The actual input has a ramp (frequency error) in
addition to a step (phase error). The slope of the ramp is proportional to
the frequency offset: larger frequency errors will result in longer lock
times.
Data recovery systems like this are typically implemented with a reference
clock, which provides a frequency close to the data frequency until data
begins arriving. When the preamble begins, the PLL reference is switched
from the reference clock to the data. In many designs, the VCO is stopped
during the switchover time, then restarted in phase with the data. The
effect is that the initial frequency and phase errors are small, so the
loop can lock quickly.
-- Mike --
Jim Thompson
times.
-- Mike --
See also "DualD-PFD.pdf" on the S.E.D/Schematics page of my website
for a more robust clearing method.
...Jim Thompson
Mike
In the PFD thread a week or so ago, Mike Monett made the claim:
My reply was:
Did you run into the same problem? It sure seems like there should be
enough prop-delay around the loop to guarantee that both flops get reset,
but the effects of failure are pretty obvious (and pretty catastrophic when
you're trying to lock quickly). For me, it showed up in a mature product,
in a very mature IC process, that had been shipping for over five years.
You'd think by that time we'd have seen every possible variation...
I implemented the same concept; in ECL, the AND and SR flop can all be
combined into one compact and relatively fast gate.
-- Mike --
Mike Monett
My reply was:
Mike, Google news was down recently, so I was unable to reply to that
thread.
Yes, of course I have had bizarre failures with existing ecl products
also. But these were layout problems or device failures, not
fundamental design issues. In the case of the phase/frequency detector
under discussion, I would not change the design. Besides, there's not
much you can do with it anyway:)
Did you change the design, or tweak the process to get it working
again?
-- Mike --
Mike
Mike
thread.
This wasn't a layout or device failure. Every part failed, in a customer's
high volume production line. The problem was with the PFD, and you wouldn't
change the design? What *would* you do?
again?
As I said in the next sentence, we changed the design.
-- Mike --
Mike Monett
-- Mike --
Gee Mike, you went from a mature, working product to 100% failure?
Scary...
What was different about the customer's usage from previous customers?
Was this the standard dual-D (or 5 NANDS PFD), or a different design?
Did you have a dedicated tester for the pll, and could you duplicate
the failure? (By dedicated tester, I mean did you have a way to lock
up the pll to a stream of clocks, then vary one bit over a suitable
range to view the response of the pll?)
What caused the failure, and what did you do to fix it?
Mike
Mike
It was a standard DFF PFD. As I've pointed out twice, the fix was to
implement a circuit similar to Jim's. If you look at his, you'll find that
the reset occurs when UP and DN are both high, but it only goes away when
they are _both_ low.
Compare that with the operation of a standard PFD, and the problem will
become clear.
-- Mike --
