12v dc power distribution circuit
John Popelish
asmo said:
Hi I'm building a circuit bent instrument with several circuits in it.
I want to run them all off one power supply rather than several
different battery packs, I want to run 4 3v dc circuits from a 12v dc
power supply, can anyone point me to a schematic?
Might be easy, might not.
How much current do each of the 3 volt loads need?
Do any signals communicate between these 4 circuits?
This is a way of asking if these circuits need to be
isolated from each other or may share a common negative or
positive supply rail.
asmo
Cheers
Ed
ehsjr
Cheers
Ed
+12 ---+---Vin|LM317|Vout---+---+---> +3
| Adj [R1] |
[C1] +----------+ [C2]
| [R2] |
Gnd ---+---------+--------------+
C1 = .1uF
C2 = 10 uF
R1 = 240
R2 = 336
Above is a simple voltage regulator circuit based on
the LM317 chip that will provide 3 volts output.
Your answers to John's questions will determine whether
you can use it in your project.
Ed
asmo
I'm not sure about the current, it consists of the circuits from 2
vtech tiny touch phones,early learning toys, which run on 2 AA
batterys each.
The 16 pins from each IC are routed to a patch bay so, yes there is
some cross wireing, the other 2 circuits are simple 555 astable
circuits which act as LFO's which can be patched into various points.
Ed
John Popelish
batterys each.
The simplest way to get several different 3 volt supplies
from a 12 volt main supply is probably to use linear
regulators, like LM317T, programmed with a pair of resistors
to produce a 3 volt output. If the 3 volt loads draw more
than about 50 mA, you will need heat sinks on the regulators
to keep them from overheating.
See:
http://cache.national.com/ds/LM/LM117.pdf
This arrangement would require that the negative side of the
12 volt main supply were common to all loads.
