1997 Phillips Magnavox
K
Kimbyj
HI
This will seem like a real dumb question but...
just purchased a 27" 1997 Phillips Magnavox on Ebay for a friend wh
doesn't have cable but has uses rabbit ears on her current TV. Much t
our dismay, we didn't check to see if it was 'rabbit ear ready' and i
is not. So...does anyone know of a way to get reception on a TV tha
only has a cable input without having cable or satelite?
Thank
Jerry G.
Modern TV sets are made to be used with cable services, or satellite
recievers.
You can go to a Radio Shack and see if it is possible to have a ballen
coil adabtor to go from the 75 ohm connector to the 300 ohm connections
required for rabbit ears. You must also find out if the tuner in the
set can recieve the local UHF and VHF stations. Most sets can cover
both the cable bands, and the standard TV terrestrial bands.
Jerry G.
Erich Schultheis, the man that owns an ISP.
Kimbyj said:
HI
just purchased a 27" 1997 Phillips Magnavox on Ebay for a friend who
doesn't have cable but has uses rabbit ears on her current TV. Much to
our dismay, we didn't check to see if it was 'rabbit ear ready' and it
is not. So...does anyone know of a way to get reception on a TV that
An almost 10 year old Philips Magnavox? Are you sure it ain't just
broken?
Mike Berger
You may have to select "antenna" or "air" from a setup menu
to set up the tuning correctly. Get an antenna with a 75 ohm
impedance, or use a balun with the old rabbit ears.
Similar threads
