2-pole active filter question
Fovakis
Jun 15, 2013
Hello! I am desiging in PSpice a 2-pole active filter. the values are taken from a wikipedia example to be sure about the fcut.
http://i1284.photobucket.com/albums/a578/fovos1/activefilter2polesallenkeytopology_zps30b85696.png
this is the circuit http://en.wikipedia.org/wiki/File:Sa...ss_Example.svg
and the fcut=16KHz. but when i am doing it in pspice the fcut is at 10khz.
i tried with other values and again problem. i read about FREQUENCY SCALING FACTOR accoring to Butterworth filter but i don't understand
why for example wiki has wrong fcut. what is this value?
at pages 9 to 10 texas instruments has some tables with FSF depending of what filter design you like.BUT ONLY ABOUT LOW PASS FILTERS....
http://www.ti.com/lit/an/sloa049b/sloa049b.pdf
please someone to explain.thanks a lot :D:eek:
CDRIVE
May 8, 2012
4,960
Your Wiki link is returning "No file by this name found".
Chris
CDRIVE
May 8, 2012
4,960
When I ran it I get the following using an ideal OpAmp..
-3dB=10KHz
-6dB=16KHz
-20dB=48KHz
Chris
