2 volt regulator
Nick Lee
Mar 4, 2018
9
Is there a chip like a lm78_ _ that will regulate down to 2 volts?
Chemelec
Jul 12, 2016
291
I have a Few MC7902CT Regulators .
these are 2 Volt Negative regulators.
Probably the 2 volt Positive ones Were also Made.
Do you mean regulators that will produce an output of 2 volts, work with a differential voltage of 2 volts, or work with an input voltage of 2 volts?
AnalogKid
Jun 10, 2015
3,051
Probably not. -2 V is the termination voltage for ECL. There was no equivalent regulated positive voltage needed for other logic families or linear components.
For a single isolated output, the 7902 can be used to "regulate the ground" and produce a +2 V output, but that technique will not work if the +2 V output has to have a ground that is common with other positive output voltages.
ak
Chemelec
Jul 12, 2016
291
Depending on his situation, this Negative one could work for him.
Chemelec
Jul 12, 2016
291
An LM317 will also Regulate down to 2 Volts or a bit Lower.
kellys_eye
Jun 25, 2010
6,512
What's the application? There are a load of 1.8V regulators for modern processors and this might be within any tolerance the user requires???
I think he is trying to burn out a red LED.
So, are you guessing, or do you have other information that you're deliberately withholding?
Either way... not very helpful.
Audioguru
Sep 24, 2016
3,656
He made only one post without saying what the 2V is for or how much current he needs. He did not say if an LM317 can be used.
Nick Lee
Mar 4, 2018
9
No Audio is almost correct, i have am trying to step down a voltage of about ~17 to about 2 for some white LEDs .
AnalogKid
Jun 10, 2015
3,051
Most LEDs - and particularly white LEDs - should be driven with a specified current, not a regulated voltage.
Part number / manufacturer / specs?
ak
Audioguru
Sep 24, 2016
3,656
It sounds like you did not measure the voltage of a white LED. It is much more than 2V, probably between 2.8V and 3.5V. You said LEDs in plural. If you connect a bunch of white LEDs in parallel then since they all have different voltages, the LED with the lowest voltage will take all the current and quickly burn out, followed by the LED with the next low voltage and it will burn out, followed by ... etc. The voltage of an LED drops as it gets warm which makes it draw more current which makes it warmer which makes it draw more current which makes it... have thermal runaway and it goes POOF!
Buy thousands of white LEDs, then test and sort them into piles with the same voltage. They do that in China to make cheap white LED flashlights. Hey, use the matched LEDs from a flashlight.
Why not connect a few LEDs in series then your current limiting resistor does not waste a lot of power making heat.
Four 3.5V white LEDs need 14V then a resistor can be in series to limit the current with 3V across it
if the LEDs are 2.8V then four need 11.2V and your current limiting resistor will have 17V - 11.2V= 5.8V across it.
Four LEDs and a resistor are a string. Connect as many strings to the 17V as you want.
Take a look here.
That will tell you all you need to know without hyperbole.
If your 17V is reasonably stable you should be able to put 3 or 4 LEDs in series with a single resistor and then just repeat that for as many LEDs as you require.
