200v 50a arc lamp PSU again :)
John Barrett
There has been some mention of using an arc welder to power a krypton arc
lamp rated at 8000w (200v/40a.. make it 50a for a little headroom)
I was under the impression that arc welders operated well under 200v output,
and was wondering if someone could explain either A> how an arc welder works
such that i could produce the output I need, or b> what modifications might
be neccessay to get the desired output ??
H
Homer J Simpson
output, and was wondering if someone could explain either A> how an arc
welder works such that i could produce the output I need, or b> what
modifications might be neccessay to get the desired output ??
Yes, typically around 30 - 90 volts IIRC. You CAN get a shock off them if
you are wet and grounded.
John Barrett
we knew this already -- I do plenty enough with my 120v arc welder on my
trailer mounted antenna tower -- do you have something to contribute that is
more in line with the question ??
H
Homer J Simpson
is more in line with the question ??
Moron.
PLONK!
Genome
John Barrett said:
dont waste my time -- say something relevant to the question.
Fuckin A!!!!!!
Plonked by Homer......
Fuckin A++++++++
**** life is just tooooooooo fucking good.
DNA
H
Homer J Simpson
Yeah. They have to be extremely stupid for that but this dumbfuck achieved
that level of failure.
Genome
Hang on.
You plonked me earlier over your inability to deal with fly by wire.
DNA
John Barrett
If wanting a responsive answer is all it takes to get plonked around here --
then I AM PROUD TO BE PLONKED !!
Its not MY fault that you dont know enough about arc welder internals to
answer my question !! (or if you do, that you choose to give me shit rather
than answer my question !!)
maxfoo
Vs jnagvat n erfcbafvir nafjre vf nyy vg gnxrf gb trg cybaxrq nebhaq urer --
gura V NZ CEBHQ GB OR CYBAXRQ !!
Vgf abg ZL snhyg gung lbh qbag xabj rabhtu nobhg nep jryqre vagreanyf gb
nafjre zl dhrfgvba !! (be vs lbh qb, gung lbh pubbfr gb tvir zr fuvg engure
guna nafjre zl dhrfgvba !!)
Go ask your question in 'sci.engr.joining.welding'
Genome
You seem to be confused.
Newsgroups: sci.electronics.design
Date: Fri, 13 Oct 2006 00:36:59 GMT
Local: Fri, Oct 13 2006 12:36 am
Subject: Re: Did Europe's new standards for pc boards ground Airubs?
Reply to author | Forward | Print | Individual message | Show original |
Report this message | Find messages by this author
Yes, I was surprised. I was talking about fly by wire and you said it was
all done by hydraulics so I took a guess at what you thought you thought
and I get to be the idiot because you are stupid.
In the meantime you snipped all that stuff you wrote about jodhpurs, warm
dubbin and the mother of the girl next door.
PLONK!
H
Homer J Simpson
"Fly by wire" is done with hydraulics. Have you not noticed what happens
when all of the hydraulic fluid in a plane's control system is lost?
jasen
mee too.
It's basically a big transformer.
connect the outputs of two (or three?) in series?
Bye.
Jasen
