250Vac/ 125Vdc SDM fuse !
export2
Jun 1, 2010
SMD FUSE is known as tiny and easily assembled. As it is for protecting semiconductor applications, especially, high anti-surge capacity must be required.
Here provides SLEETECH SMD 1810 fuse with the smallest dimension & high anti-surge
capacity for reference.
Dimension : only 4.5x2.5x1mm---> Very tiny & slim
Voltage rating : 250Vac/ 125Vdc
Ampere rating : 0.5A ~ 8A
Due to fuse element is made by wire, instead of solder plated, this SMD 1810 fuse
owns more accurate current expression. Heat transfer is great so that it could be designed
into very tiny size but with upto 250Vac/ 125Vdc rating.
Most important is this fuse allowing AC or DC currents to pass through. Providing
convenience for designers.
The fuse performance :
It could keep stable under inrush current. Tolerance of surge & current is large.
Under abnormal current, fuse will open immediately to prevent circuit boards from
getting burned, arc or jump fire established. Actually, filament will become a ball
while melting to isolate power against re-connection!! Much more safe !!
Above information for your reference. Hope they will be helpful to you!!:)
Please mail to me, if you have question related to this fuse.
