27" RCA TV Model:F27665 ~ Chassis:CTC203AX (Video?)
AgapeDisciple
Turned on my TV the other day and was missing video. Can still change
channels, hear audio, see the raster lines (I think), and go through
the menus. But I can't get video from the coax, s-vid, or rca inputs.
I saw where a couple of other people had the same problem a while back
and it was mentioned to "clean the glue off L14401 and resolder it."
But it didn't look like that solved their problem.
Any ideas?
Logan
gnk
Check for a bad connection on Connector P103 pin # 4, also check R14119
(15 K 2 watts).
GNK
AgapeDisciple
Thanks GNK! I'll check it out tonite.
BTW, did you have this same problem?
Logan
AgapeDisciple
I resoldered P103 Pin #4 and checked R14119 = 13K ohms. (Is that too
low?) I also checked the error codes. Here's what came up:
1 - 3 | 03 | 12.0V run fault | 12.0V source is failing.
2 - 3 | 03 | 12.0V run fault | 12.0V source is failing.
3 - 44 | 2C | F2 PIP module error | F2PIP fails to acknowledge.
And I resoldered L14401.
Any more ideas?
Logan
gnk
The only other information I can find for this chassis with similar
problems is to check for a Leaky C14112, .01/1kv, causing R14119 to
overheat.
Good luck.
GNK
