27" RCA TV VCR DVD.
Dani
Model # 27F501TDV A Chassis # M5Q18, no vertical, the IC was blown
apart. Replaced the IC LA78041, 2-100 uf 50 volt, 1-4.7 uf 50 volt,
1-3.3 uf 250 volt caps, & 30 volt zener, then @ turn on, the IC blew
apart in an instant. Is this common failure for this unit? Dani.
Sofie
No.... it is not a "common" problem with this chassis.... did the zener
diode blow too! (could be a clue)
...... you may have done so already but I would look for shorted diodes
around the chip circuitry... also look for proper B+ going to the chip,
make certain that it is not too high, unregulated or worst case un-rectified
because of a shorted rectifier diode. Lastly, "ring test" the yoke
windings.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
