3-5V DC @50mA from 230V AC without transformer
nikhil arora
Mar 1, 2006
37
Can any one suggest a Circuit for getting
or any other ways.
Shahriar
Mar 18, 2004
451
Hi
The circuit I have attached is from a Project in project section of this site with this topic.
" Courtesy Light "
you can use the power section of this project with some changes.
Once I saw a project on the web with this title." Transformerless Power supply"  as I remember it has did the same trick.
HTH - Shahriar
Tony_Stoynov
Dec 20, 2005
197
in the post above, you can see ones of the possible decision, but this decision has one disadvantage, minimum dispersed power @50 mA is it around 5 W. If you not have a space for a big components, or you want cold device, the better choices is using of SMPS, i can suggest TNY series from Power Int.
Look here : http://www.mcu-bg.com/mcu_site/viewtopic.php?t=1052&postdays=0&postorder=asc&start=75,
you can see the TNY and TOP sch, also if you look at all topic, you can see the different diagram for directly 220 V power supply.
Shahriar
Mar 18, 2004
451
BTW, If you don't want to build one, You can buy a Mobile Charger and enjoy it...
HTH - Shahriar
Staigen1
Oct 26, 2003
695
Hi nikhil arora
Her you have your requested cirquit to get 3 to 5 Volt DC from 230 Volt AC without transformer, as a matter of fact, there is 2 of them, one with only positive output related to common, and one with both positive and negative output related to common.
[move]A little VARNING here! This is LETHAL![/move]
//Staigen
steev
Sep 25, 2005
49
can we glow a 3v led(@20-30ma) using above schematic.
iam also looking for such circuit.it is for powering a single led.i can't use transformer as there is no enough space.
i tried in groups(google) most of them look dangerous to me.
is there any safe design
steev
Sep 25, 2005
49
i found 2 ckts for this purpose
http://www.geocities.com/tjacodesign/supply/supply.html
http://www.electronics-lab.com/projects/power/022/
which one u think efficient and safe for driving an led
audioguru2
Apr 6, 2004
12,022
The text in the 1st one says it is not efficient and is not safe.
The 2nd circuit is the same.
