32 khz clock signal
parkie
Apr 23, 2010
Hello, i am wanting to know how to clock down a 32 khz clock to 16khz?
I am not sure if there is a quick and simple way to do this
reason is i have an amega328 running arudiuno and i am taking it off the prototyping board and putting it into a final product, but i only have a 32 khz or 8 khz clock here with me
So is there a way to clock down the 32 or clock up the 8?
or does it matter if i run the amega328 at a faster clock?
If the amega328 (and the software on it) can handle the higher clock rate, then there is no problem.
Dividing the clock by 2 is the easiest and can be done with a single flip flop.
Check out this and this.
There are simple devices that consist of a single D type flipflop that you could use in a minimum of board space. A NC7SZ74K8X is one option (I suggest this only because I have some of them) -- there are many other options.
edit: OK, 32kHz, not 32MHz. It would be no problem for the amega328, the issue would be if the software was designed specifically for the slower clock speed.
vk5ajl
Feb 1, 2010
8
As mentioned above, a D flipflop makes it easy to divide by 2. One commonly available chip is a half of a 74hc74. Connect the inverting output (Q bar), to the D input, the clock to 32kHz or whatever then take the output from either the Q or Q bar output. Perfect divide by 2 and by two again with the other half of the chip if you want.
