40-pin controller IC identity?
SparkyGuy
Haven't been able to identify this controller. Don't need replacement; it's
got custom code, I'm sure. Would be nice to have pin IDs.
<http://img6.picsplace.to/img.php?file=img6/27/CliffordPCB.jpg>
It's from an old Clifford Intelliguard 200 car security system, vintage early
90's.
Anybody happen to have external wiring diagram or schematic for the PCB?
Thanks.
F
Frank Raffaeli
90's.
Thanks.
It's a wild guess, but that's an old National Semi logo. I'd check the
COP8 family, because it's low cost, e.g. COP888CG (comes in a 40 DIP).
Frank
Meat Plow
Frank
National MM9224.
Lionel
Looks like a custom mask-programmed micro. It's a Nat-Semi of some
variety, but I'm not familiar enough with their range of
microcontrollers to make an intelligent suggestion as to which one. If
you can find the right 'family' on their website, you should at least
then be able to identify clocks, power & I/O pins, if that's any help
to you. You might also try contacting a support person there & see if
they have any ideas:
<http://www.national.com/>
Spehro Pefhany
I'd guess it to be a COP8 8-bit CMOS microcontroller (mask
programmed). Clock should be on pins 6 and 7, which it looks to be
(axial-lead ceramic caps, 1/8W bias resistor and 2-pin resonator in
the photo). You should see a clock on pin 6.
/Reset should be on pin 34 (but it looks to be tied to another pin).
Vcc should be on 8 and GND should be on 33.
Eg. COP688CL/COP988CL
Best regards,
Spehro Pefhany
Ryan Weihl
or could this be a SC\MP version of NatSemi. discontinued
see heavier traces on 20 and 40
rw
K
krw
I thought about SC/MP, but '92 sounded a bit late. The SC/MP was out
in the late '70s. I wouldn't have thought it survived that long.
F
Franc Zabkar
Almost certainly not. 9224 is the date code.
AFAICT, the date code of Q15 is 9920 and for the relays it is 9807.
Would it make sense for a manufacturer to use old mask ROMmed stock in
a new design?
- Franc Zabkar
F
Franc Zabkar
Identify the other ICs and work backwards.
90's.
AFAICT, the date codes for Q15 and for the relays suggest that it was
built as late as 9920. Is this confirmed by the date codes on the
other chips?
Thanks.
- Franc Zabkar
F
Franc Zabkar
Best regards,
Spehro Pefhany
A search of Google Groups suggests that the 16-pin chip may be a
ULN2003 which would confirm that the uP has 8-bit IO ports. Tracing
the ULN2003's inputs back to the uP would identify the uP's IO pins.
- Franc Zabkar
Michael Black
a new design?
Something that's mask programmed, you don't want to buy in small quantities.
Hence so long as the design is still viable, you don't want to change
things until you absolutely have to (such as running out of that mask
programmed device, or something else is just no longer available).
Michael
a new design?
Yes. Where I work, we have "masked" [actually they are OTP, but they
are factory-programmed and sold as "masked"] COP micros dating back at
least five years. We'll still be making those products five or six
years from now, and those chips were last time buy two years ago. Less
expense and trouble to do a last time buy for the product's expected
lifespan than to port everything to a new micro.
Lionel
Were they still making the SC/MP in '92? The last time I saw an SC/MP
was in 1980!
CJT
90's.
Thanks.
You'll have to wait until 2008 when the picture becomes available.
SparkyGuy
The 8-pin says "3-544" and is probably a 73-544 clock gen. The resonator is
right there between it and the 40 pin'r.
other chips?
I've owned since about mid '98. The relays were replaced maybe ~'99. Don't
think the transistor was replaced, but might be.
F
Franc Zabkar
Could it be a house-numbered serial EEPROM, eg 93Cxx ???
According to the datasheet for the COP8 ...
port pin# function
G4 3 SO (MICROWIRE Serial Data Output)
G5 4 SK (MICROWIRE Serial Clock)
G6 5 SI (MICROWIRE Serial Data Input)
I think the DIP-14 and DIP-16 IO chips should give you a clue as to
the uC's port layout. I'm betting that one chip drives various
external relays while the other accepts inputs from sensors.
- Franc Zabkar
