W
Winfield Hill
- Jan 1, 1970
- 0
Question: Did anyone ever build the high-voltage requlator
circuit, using a FET and an LM317L, that I posted here a few
years ago? I have just reposted it in answer to a quesiton
on sci.electronics.basics, and wonder if it works properly.
Group: sci.electronics.basics
Title: Re: Transistor regulators?
Author: Winfield Hill
Date: 22 Nov 2003 11:17:29 -0800
John Popelish wrote...
From a post of mine made a few years ago: ... a simple
high-voltage regulator that uses standard LM317 or LM317L
chips plus an easy-to-get reliable high-voltage MOSFET.
600V FET _____ LM317L 5 to 500V
IN o----+----, ,-+-----+--| |--+---+----+---o OUT
| | | | s | | | | | | 2 to 100mA
| _|_V_|_ | |_adj_| 1.2k | |
2.2M ----, | | | | | 0.47uF
1/2 W | '-||--+-----+ | ===
| | , 68pF | | | 630V
' 10V zener | 2.7 ohms
500k |
pot gnd
gnd
The FET needs a very serious heat sink, because 450V at
100mA is 45 watts, and under a short circuit condition the
LM317L may allow even more current to flow. You can add
a single-transistor foldback current limit if you want.
Add a 1n4002 diode backwards across the LM317 if you plan
on ever shorting out the input filter-storage capacitor.
(Always use drain resistors with high-voltage capacitors.
And always approach the open circuit with one hand behind
your back.)
The LM317L needs as much as 2.5mA to operate, and the 1.2k
resistor only takes 1mA, so this sets a 1.5mA minimum load
requirement. (Note, you could use 470-ohms instead of 1.2k,
but this would require a 200k pot with 1W of dissipation,
instead of the 0.4W maximum dissipated in the 500k pot when
it's set to about 400k for +400V out.)
Note: I haven't tried this circuit, since I prefer to use
HIP5600 and VB408, etc., high-voltage regulator ICs.
- Win
whill_at_picovolt-dot-com
Field effect transistors are probably your best bet for this service.
They are commonly available with voltage ratings up to about 1000V and
power dissipation ratings high enough to survive a short circuit while
current limiting, if they are mounted on a large enough heat sink.
| | , 68pF | | | 630V
500k |
pot gnd
gnd
your back.)
- Win
