466 TEK Scope problem FOUND! -Question on replacement IC
Chris
Hey guys. I have finally found the bad part in my TEK 466 Scope. It is
the Op amp 156-0158-00 Mini-DIP, Motorola, Op Amp, MC1458P1 it says
RCA 827 at the bottom.
Any idea if I can swap this out with one from Radio Shack? Or does it
have to be a Tektronix one of identical make?
If I can swap it, can someone tell me what 8 pin Op Amp model I can
use instead of this one? And will it affect calibration or should it
be ok? -It's the op amp off of the +15v power supply schematic on my
466 scope.
Thank You,
-Chris
James Sweet
466 scope.
Thank You,
-Chris
The 1458 op-amp is a really common part, why not just get the right one?
Here's one of many places selling it
http://www.kelvin.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=600026&Category_Code=ELPCICMI in this case it's a whopping 36 cents.
Jim Yanik
chris1@oupower_dot_com (Chris) wrote in
466 scope.
Thank You,
-Chris
I would not substitute other IC types,you can use a generic 1458,dunno if
RS has them.As another has posted,the 1458 is still available,and
inexpensive.
Chris
Thanks guys, I ordered the MC1458P from Mouser. I should be all set in
a few days when it arrives. I did notice something cool however.
I'm half tempted to try this because I'm anxious to see it work again
and know that I got everything. I'd hate to still have more bad parts
that I have not yet found.
The Op Amp is a DUAL chip. In the schematic it's clearly using the 2nd
amp and the first side seems to be just sitting there. I bet I could
re-wire my current chip to work if I just utilize pins 1, 2, 3 instead
of the 5,6,7 that it is using now.
I'm very tempted to try this. I will still need to use pins 4 and 8
for the Vcc + / - , but as long as those 2 pins are ok, my idea seems
sound that I could just use the other side of the chip *lol*
Your comments are most appreciated :)
-Chris
Jim Yanik
-Chris
if RS has them.As another has posted,the 1458 is still available,and
inexpensive.
Why bother? Go to Radio Shack,see if they have one,or an ECG equivalent
from a local distributor.
Chris
Radio Shack doesn't have anything but some stupid shit :) lol. I will
just wait until it comes in the mail I guess :) I did discover last
night that it uses both sides of each Op Amp so I can't do what I was
talking about. I thought it odd that it would only use 1/2 so mystery
solved. I need a 4158 or equivelent. I called all the TV Repair shops
nearby but turned up nothing :( Guess online is my only recourse.
That's kind of a shame.
-Chris
Jim Yanik
-Chris
Don't call TV repair shops,call the local *electronics parts distributor*.
Chances are they sell ECG parts,and there's an ECG version of the 1458.
A TV repair shop isn't going to want to sell you parts.
Sam Goldwasser
Isn't the MC1458 just a general purpose vanilla flavored op-amp? Why all
the fuss? Almost anything with the industry standard pinout would likely
work, at least as a test. :)
--- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: The email address in this message header may no longer work. To
contact me, please use the Feedback Form at repairfaq.org. Thanks.
Jim Yanik
all the fuss? Almost anything with the industry standard pinout would
likely work, at least as a test. :)
It's a dual op-amp.
Sam Goldwasser
It's a dual op-amp.
Sorry, yes I know, my slip. The point is that everyone is going obsessive
about getting the exact replacement.
James Sweet
But... didn't he say he already ordered an exact replacement? It's cheap
enough, why is this thread even still going?
Sam Goldwasser
Beats me. :) But ordering a 50 cent part from Mouser still has a several
dollar shipping and handling charge!
Asimov
"Jim Yanik" bravely wrote to "All" (16 Nov 03 01:05:08)
--- on the heady topic of "Re: 466 TEK Scope problem FOUND! -Question on replacement IC"
JY> From: Jim Yanik <[email protected]>
JY> A TV repair shop isn't going to want to sell you parts.
I noticed that repair shops in general are not the most sympathetic to
hobbyists. A pox on them! ;-)
.... Techs would rather pee on an electric fence for the light show
TekMan
inexpensive.
The TL072 / TL082 worked well in my repairs.
Also substitutes from PMI did.
But avoid all dual opamp types with BW-gain produkt of more than 3MHz.
Then oscialltion might occur in some cases.
When you look at the circuit, yo usee that the regulation is well
designed, there is no voltage stress on the opamps (everything stays
very well below the maximum supply voltage limits).
HTH,
Andreas
Sam Goldwasser
If the original op-amp was anything with a "X58", almost anything with
the same pinout will be at least as good! :)
TekMan
Well sam, but modern types of opamps have similar pinout, but
sometimes MUCH higher BW.
That's the point I wanted to make shure it's noted.
Because it's no fun to run into an oscillating pwr supply problem.
hth,
Andreas
