555 used as a delayed pulse generator?
Tristar
I'm looking to set us a simple way to turn something on after 10 seconds. The
resulting output after the end of the 10 seconds needs to be a momentary pulse
and not stay in a closed position.
Like this.
Circuit is started with a momentary contact switch. After 10 seconds (exact time
isn't critical here +, - a second or two is fine) the circuit momentarily
outputs a pulse. I thought I'd feed the pulse into a switching transistor to
make it operate as a momentary contact switch.
Thanks in advance!
Lawrence
Charles Jean
Like this.
Thanks in advance!
Lawrence
___
Here's one that gives about 1 second delay, 1 second pulse. Could
also use one 556 instead of 2 555s. Delay/pulse is 1.1RC where R is
the 22K resistors and C is the 47 uF capacitors.
"Sic hoc legere scis nimium eruditionis habes."
(If you can read this, you're overeducated.)
Terry Pinnell
Like this.
Thanks in advance!
Lawrence
This does what I think you want:
http://www.terrypin.dial.pipex.com/Images/10sMono+Pulse.gif
Tristar
This looks easy Terry, I tried Johns circuit on a breadboard last night. I'll
give this a try too.
Thanks, Lawrence
BTW, nice website you have there.
Jasen Betts
Like this.
set up the 555 as a monostable and use a capicitor in series with the output
to pulse the transistor's base when the output changes state after the 10
seconds have elapsed. (there'll bve a pulse to the transistor when it starts
too but it'll be the wrong polarity and the transistor will ignore it)
Terry Pinnell
That's what my circuit does.
Tristar
Hi Terry, It's probably me but I couldn't get it to work, I used a pnp 2N3906.
I tried various combinations of caps and resistors but no luck.
Any ideas?
In
Terry Pinnell
Any ideas?
In
Without more information, not really. Best guess would be that you've
made a wiring error. As you see from the simulation - the circuit does
what it's supposed to do.
How are you testing it? 'Scope, DMM...?
Is the mono working? If not, then obviously the brief pulse won't be
generated.
Tristar
Hi Terry, I gave it another try and Success this time!
Thanks again,
Lawrence
Terry Pinnell
Thanks again,
Lawrence
Good - thanks for letting us know.
BTW, *bottom* posting is the favoured standard here.
SARAH
Oct 19, 2010
Dear Mr. Terry,
Kindly precise the transistor used in your circuit, as I tried BC556, and the result was not a pulse, It is remaining high.
Actually I am trying to have a delayed 3 seconds pulse with 1 second width.
Best Regards,
Sarah
