5804 arm/disarm assign code question
Crash Gordon®
This drives me crazy all the time.
I have 5804 on Vista 15P.
Loop 1= Fire
Loop 2= Off/Disarm
Loop 3= Arm
Loop 4= Panic
I can't remember how to add the code for the Arm/Disarm Buttons to work. I assigned User 31 = a code, but when I add the attributes...I dunno what the "Value" is supposed to be. Or is the "value" supposed to be the user code????
Their instruction books are getting better!...but I still can't find what I'm doing wrong. The user 31 code does work if I arm/disarm from manually from the keypad.
tnx
Rob
A.J.
I am not sure if the 5804 needs a user code to work with a 15P.
Loop 1= Fire
Loop 2= Off/Disarm
Loop 3= Arm
Loop 4= Panic
code????
from the keypad.
tnx
Rob
Crash Gordon®
It does, but only for the arm/disarm - the panics work without user code.
A.J.
If it does, you would see the option on a Alpha keypad when you are
programming the user number.
Something like [RF Button]
Crash Gordon®
Yah...I got it...just a brain fart. I'd programmed it correctly, but when I tested it I just didn't hold down the ARM button long enough...sheesh what a maroon! - wasted an hour with that.
Loop 1= Fire
Loop 2= Off/Disarm
Loop 3= Arm
Loop 4= Panic
the
code????
from the keypad.
tnx
Rob
Mark Leuck
You would if it was while changing user codes in a Vista-40 and up but it
doesn't show on a Vista-15P/20P even tho you do have to do it
G. Morgan
Subject: Re: 5804 arm/disarm assign code question - disregard
Newsgroup: alt.security.alarms
hmmmmmmmmm.............
Crash Gordon®
hey it was late...my brain was fried, probably by some Belgium RFI muzzlement...what can I tell ya ! :)
anyway...it's alll programmed and tested ready to install tomorrow - just pop it in.
