aussiblu
- Jan 1, 1970
- 0
The temperature gauge in the NB Fairlane has been over-reading.
After confirming it was not overheating. checking the wiring,
improving ground connection and changing the sender I found that
it was the gauge (i.e. when the sender read 70 ohm the gauge was
over normal near the red when it should have been exactly in
middle of normal - if I read the resistance at the sender or the
plug on the back of the gauge). I have the factory manual that
gives gauge positions and resistance readings.
Some times the gauge reads OK and accurate but when the cabin
temperature gets warm it plays up - annoying as I was usually
working on the car in the evenings and the fault wouldn't show
so I started taking my Multimeter with me and checking the
sender's resistance whenever the gauge said the engine was hot
and tracked it down that way.
I dismantled the VDO digital gauge set tonight have found the
fault. There is a brown linear resistor type component on both
the fuel and temp gauges marked 88R the one on the fuel gauge
has 88 ohm resistance while the one on the temperature gauge
reads 56ohms at a room temp of 22 degrees C. I suspect these
brown linear components are protective thermistors and the one
on the temp gauge is no longer stable. Can anyone confirm they
are thermistors (or advise otherwise) and tell me a source for a
replacement (tried RSComponents, Farnell, Jaycar, Altronics and
Worldwide Electronics sites so far with no luck).
Can I join lower R rated thermistors in series or put a resistor
in series with a suitable lower R rated thermistor? Other than
voltage and ohms I will be sort of guessing the specs for a
thermistor anyway.
If not I suspect I will have to buy a whole new gauge if Ford
still have stocks or more likely go looking for a whole new
gauge set with a working temp gauge.
For car nuts that think they know Ford model series; yes there
is just one NB model Fairlane. see
http://www.trueblueford.com/RossNBfairlane.html It's an ex Ford
prototype so it also had a gauge set and sender unit from a
later model just to confuse things further.
thermistor anyway.
