A followup to "AB Landola semi-acoustic guitar electrics ,c 1960s"
N
N_Cook
Some pretty pics for a change, finished pickup rewind
With some 1960s Pekalit red bakelite and brass knobs that I happen to have a
supply of, far more in keeping than the "original" ? grotty loking grey
aluminium Japanese ones.
http://home.graffiti.net/diverse:graffiti.net/landola2.jpg
http://home.graffiti.net/diverse:graffiti.net/landola3.jpg
owner agreed
(before tidying away the internal wiring)
I now know it is possible to remove pots and brasswork mounts through the
soundhole
ps
there may be disallowed remote linking with this host, anyone finding that
please feedback here. Seems you sometimes have to repeat attempt to access .
N
N_Cook
Meat Plow said:
access .
Would have been nice to see some pictures larger than 200x200 pixels.
Basics of frequency response of pickups anywhere?
Using a 390uH wire-ended axial choke for injector
in place of guitar string and an AF generator
and comparing roughly, the frequency response.
The rewind was about the same at 100Hz , less
at 1KHz and more at 8 KHz
Presumably more insulation on the replacement wire for less
distributed C, but mid-range drop ?
Can't do much about the choice of wire , so doesn't leave much to play with
N
N_Cook
Geo said:
Pinched from the thread in sci.electronics.design
Subject: Audio Circuit for *High* Output Impedance
http://tinyurl.com/mdyxtz
which takes you to:-
http://online.physics.uiuc.edu/courses/phys498pom/Lab_Handouts/Electric_Guit
ar_Pickup_Measurements.pdf
Not exactly the "basic" info perhaps.
A good academic treatise , but I'm more interested in the practicalities.
Correlation between winding weave/dimensions/ changing magnets etc for a
given constraint within a particular housing and wire type, what correlation
on the output frequency characteristic.
