A question about the rubber contact strips for LCDs
Eric R Snow
Greetings All,
Common in many LCD displays are rubber contact strips which are the
connection between the Circuit board and the glass LCD assembly.
Looking inside one device I noted that an exact contact strip
placement in the long direction was not possible because of mounting
tolerances of the circuit board to the plastic case holding the LCD.
Using a magnifier to look at the strip it appears that there are
strips of two different materials all bonded in a stack. So I'm
thinking there is a conducting strip then an insulating strip then a
conducting strip etc. Is this correct?
Thank You,
Eric R Snow
Larry Brasfield
Eric R Snow said:
Greetings All, Hi.
Yes. That strip is known as "zebra strip".
It works well for low current connections that
are not sensitive to small voltage drops.
Thank You,
Welcome.
