abt some problem with nyquist's and shannon theory
H
hardik
hello friends,
I need to solve this 2 poblems if anybody can help me out.
Problem 1: A collection of 10 routers is fully connected (a line
between each
pair of routers). How many lines do we need (assuming each is duplex).
Problem 2: If a binary signal is sent over a 4-kHz channel whose
S/N ratio is 30dB, what is the maximum achievable date rate? (you must
check
Shannon and Nyquist and pick the smaller estimate).
I m waiting for ur reply. If I will solve these problems I will post
the answer.
thx,
-hardik
Jim Thompson
hello friends,
between each
check
the answer.
thx,
-hardik
And how many CEU's will I get for doing YOUR homework?
Go away kid... go flip burgers somewhere.
...Jim Thompson
K
Ken Smith
hello friends,
between each
This one has an obvious math answer which is in fact wrong. If you've
ever tried wiring up a number of routers or anything else, you will know
the right answer is more than the simple one.
You need to know the following added information to get the real answer.
What day of the week is it and what is the time?
How far is it to the store to buy extra cables?
What are the hours of said store?
Did you buy those cheap cables in the bin?
BTW: the first version of this problem involved "speaking tubes".
check
In this one, it depends if you are in marketing or engineering.
Jim Thompson
Bwahahahaha ;-)
...Jim Thompson
F
Fred Bloggs
between each
I take "duplex" to mean full-duplex so single cable comm. Then
conceptually label the routers 1,2,...,10, and the cabling would go as
(1,2),(1,3),...,(1,10),(2,3),(2,4),....,(9,10) where (m,n) denotes the
check
This is easily answered by reference to this piece written by a
pseudo-intellectual pedant:
http://en.wikipedia.org/wiki/Shannon-Hartley_theorem
C= BW x Log2(1+S/N)= 4e3*Log(1+1000)/Log(2)=40Kbps for Shannon
Nyquist's Theorem applies to the equivalent bit rates of noiseless channels:
C = 2*W log base2( L ) bits/sec
o where 2W is 2 times the highest frequency contained in the
noiseless channel, and
o where L = number of discrete levels (e.g., binary = two levels, 0
and 1)
C=8e3*log2(2)= 8Kbps
Despite the claims of others, real life is just this simple.
K
Ken Smith
and 1)
Despite the claims of others, real life is just this simple.[/QUOTE]
Except the answer you gave is wrong. Go back and re-read his homework
question very carefully and you will find the mistake quickly, (I assume
based on my past experience with you)
F
Fred Bloggs
and 1)
[/QUOTE]
The Shannon answer is right for the case where you have the freedom to
use multi-level encoding or a symbol set greater than two. The OP states
"binary signal," so that Shannon does not apply in this case. The
Nyquist answer is an assumption based on two level detection at the
receiver.
F
Fred Bloggs
and 1)
[/QUOTE]
You must be saying that because the analog bw of the channel is 4K then
the this will only support a data rate that represents 2 samples or 2Kbps.
F
Fred Bloggs
and 1)
[/QUOTE]
The 8Kbps is right for the Nyquist answer, derived from zero ISI
considerations, when you forget about the fact that this requires pulses
of the form sinc(2piWt)- and that is binary in a strict sense. Anything
else does not refer to Nyquist's original theorem.
K
Ken Smith
and 1)
the this will only support a data rate that represents 2 samples or 2Kbps.[/QUOTE]
Yes, the homework problem says "binary" signal.
Huh? The Nyquist Theorem say that a channel of bw=H=4Khz using V=2
states has a maximum capacity of 2H*log2(V) = 8Kbps. Doesn't "binary"
in the question simply mean 2 states? I think Fred's first answer is
correct.
K
Ken Smith
correct.
You've got Nyquist standing on his head.
\ / O
O / \
2 <-----> ---
K
Ken Smith
else does not refer to Nyquist's original theorem.[/QUOTE]
Since part of the sinc() function must appear before Nyquist was born, I
suggest you re-cast that in minimum phase not zero phase.
BTW: Isn't this just a way to sneak a multilevel encoding in?
F
Fred Bloggs
[/QUOTE]
Nyquist was working with the noiseless telegraph channel with brickwall
bandlimiting to find maximum pulse rate with zero intersymbol
interference, or the equivalent thereof in his day, 1920's or something.
The ideal solution is pulses of the form sinc(2piWt) at a rate of 2W is
the maximum possible. This was easily extended to the Log2(L) multiplier
term for multilevel. As usual there are an infinity of extensions to
this with ordinary digital pulses, raised cosine, and others, but they
are non-closed form, parameterized with BER against types of noises and
noise power, and they are not called Nyquist's Theorem. This comes right
out of Digital Communication Techniques, Signal Design and Detection,
Simon, M.K., Hinedi, S.M., Lindsey, W.C. (<- well known mega-expert),
Prentice Hall 1995, Chapter 9 Communication Over Bandlimited Channels,
Section 9.2.1 Nyquist Criterion for Zero ISI, pg 561.
K
Keith
\ / O
O / \
2 <-----> ---
Whew! I thought I was losing it.
K
Ken Smith
Oooops, I miss read your post. Yes, the highest frequency needed to do a
bit stream is 1/2 the bit rate.
K
Ken Smith
Ken Smith wrote: [...]
I think you may have misunderstood the crack about the sinc() function.
You can also shift the phase of the higher frequencies later to make a
minimum phase signal. This signal has the exact same bandwidth as the
sinc() but doesn't require non-zero values before Nyquists birth.
Richard Henry
OK, now you've got him lying on his back.
