Accurate temperature control for water heater.
Mick tozer
Dec 24, 2017
3
Hi,this is my first post,I'm looking to make a small heated water bath to accurately warm and temper chocolate,sweets are my hobby...the commercial tempering machines are quite expensive,so I wondered if it would be possible to build a simple control circuit with a sensor,then I wondered if I would have to modulate the heater rather than just on/off...the problem with chocolate tempering is it needs to be very accurate,a couple of degrees makes s difference,would appreciate any thoughts. I'm an ex engineer and now a plumber,but my electronic knowledge is sketchy! Thanks.
kellys_eye
Jun 25, 2010
6,512
Modulating the heater shouldn't be necessary given the latency of the liquid you're heating but consider having a circulation system to thoroughly 'mix' the liquid being heated.
Either way there are numerous thermostats (electronic) that can manage the control process - they usually (but not always, so check) come with the relevant temperature sensor.
I have a junk box digital controller I bought via eBay (Chinese delivery) that is programmable for upper and lower limits, hysteresis etc that cost me (IIRC) around $20.
The answer is a sous vide machine.
There are various immersion type sous vide heaters that include circulating pumps. These devices typically have PID controllers and accuracy to a fraction of a degree.
One of my colleagues used his sous vide cooker for tempering chocolate quite frequently.
Edit: obviously (I hope) with this method you put the chocolate in a bag, all of these methods keep a water bath at a highly consistent temperature.
Mick tozer
Dec 24, 2017
3
Wow! That's brilliant Steve,I've heard them mentioned on cooking programs,sounds like the way to go,especially with the accurate temp control.
