ADCs ... noise is it normal?
Hi all!
I`ve choosed TLC4541 16-bit ADC for my design.
One thing is driving me crazy ..when I connect Vin to Vref (+5V) and do
few measurements one by one i do get quite big noise(error)
here are some samples :
FE4E
FE7E
FE84
FE55
FEC9
FEC9
FE96
FE68
FE56
FE73
FE86
to get acceptable error(nose) [+/-4] i need to do averaging of 1000
samples
again some samples...:
FE85
FE83
FE84
FE85
FE83
FE84
FE84
FE84
FE83
FE85
FE85
FE84
FE85
FE84
FE84
FE84
FE84
FE85
FE85
FE84
my question is:
is it normal for ADCs, or I choosed a bad one?
best regards
DM
Hi all!
my question is:
Have you hung an oscilloscope on the ostensibly stable voltage that
your A/D coverter is sampling? And on your reference voltage input?
With the ground clip of the oscilloscope probe attached to the 0V net
close to the poit where the A/D converter is connected to the 0V net
(pin 3) ...
Note that the LSB on your A/D converter output is only 76.3uV. The 123
LSB range on your raw data is a 10mV peak-to--peak excursion - you will
need to set the scope gain fairly high and use AC coupling if you want
to see this kevek of noise on an oscilloscope,
Unless your circuit has been carefully constructed, it is very likely
that your A/D converter is okay, and correctly representng the rather
noisy signal that you are giving it.
no i do not have osciloscope in here but i did like thist
i used tl431 to get 3V and connected it to Vref and Vin.. what i get is
... noise..
FF80
FFB8
FFB8
FFB8
FF8A
FFBE
FFA6
FF80
FFB8
any idea ?
best regards
david
Roger Hamlett
Hi all!
FE4E
<snipped>
You need to look at _everything_. Start with your Vref. How is this
generated?. How does it's ground connect to the ground of the ADC?. How is
it smoothed?. Then the same questions for the sample voltage. Then how are
the digital lines routed relative the analog signals?. You are actually
achieving about 10bit accuracy. The ADC you have, on a properly laid out
board, is capable of doing vastly better than this.
Best Wishes
Meindert Sprang
.. noise..
FF80
FFB8
FFB8
FFB8
FF8A
FFBE
FFA6
FF80
FFB8
any idea ?
Your PCB layout and power supply are probably not designed properly. I
remember my first-ever 14ADC design: an ADSP2101 on a board, a power and
ground trace pair running from power supply to the DSP, the ADC and the
input amplifier (working in the mV ranges) in exactly that order. I think I
got about 8 bits of noise.....
Meindert
Bill Sloman
[email protected] wrote
Hi all
One thing is driving me crazy ..when I connect Vin to Vref (+5V) an d
<snip
my question is
(pin 3) ..
wil
