adding a memory card to single-chip CPU
David Collier
I'd like to add a removable memory card ( 128Mbytes or more I suppose )
to my tentative design, which uses the AT91SAM7x128 processor. As far as
I can see the processor has no in-built assistance for communicating
with a CF, MMC/SD, smartmedia or any other external flash device I might
consider.
In particular I can't instantly see that I can output a read or write
strobe so I may have to bit-bash the whole dratted read and write
cycle... though you may know better.
I've designed ( on another project), but never built, a smartmedia
interface, which requires about 12 pins. I could handle that, and I
could use it for a soldered-on NAND flash if I liked too, so that's a
bonus.
I believe the MMC/SD card has a serial mode which looks a bit SPI-like,
but I know nothing more about it. Anyone know if you can actually use
all the memory over that interface? Is it SPI?
The ideal would be a 2cm square device with a nice simple interface,
which corresponds to a nice simple interface in the 7x CPU which I don't
happen to be using. :)
Anyone got any suggestions, or know of any Atmel/other application notes
on the subject?
David
John B
consider.
bonus.
on the subject?
David
I have interfaced ATmega128 to SD memory cards with the built in SPI interface. It's very easy with
a couple of caveats. Firstly SD is 3.3V so M128 signals have to be fed through a couple of
resistors and secondly it is not possible to use the #CS pin of the SPI interface as the SD card
pulls this line low to indicate its presence. You need to use another pin.
Progressive resources have a useful FAT 16 library for M128 but I dont know if it is ported to the
ARM yet. Have a look at
http://www.prllc.com
On Mon, 13 Mar 2006 11:16 +0000 (GMT Standard Time),
consider.
bonus.
on the subject?
David
Everyday Electronics starting May 2005 had a good article on how to
talk to CF cards... they were ultimately looking to get a PIC talking
to it so with some tweaks, it sounds right up your street.
H
Tim Wescott
consider.
bonus.
on the subject?
David
Circuit Cellar covered this in detail a few months ago, using a 3-wire
interface to memory cards.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
