adding a sprocket to a motor
Phil Allison
I am into building electric bikes.
Can you give me any advice on how to install a sprocket to an electric
motor?
** Well, it is like this:
1. First catch your sproket gear.
2. If the motor shaft has no flat - file a small one.
3. Slide sprocket gear onto the shaft, align the grub screw and tighten it
like mad.
Worked for me.
......... Phil
that simple?
okay thanks.
so I guess a machine shop would better do the job for more precise and
balanced jobs.
know any site with pictures?
Peter Bennett
Hi!
motor?
The motor shaft is probably some standard size, and may, or may not,
have a flat or keyway on it. You just have to buy a sprocket that
will fit the shaft diameter, and has a setscrew to secure it to the
shaft (works best with a flatted shaft), or that takes a key to match
the keyed shaft.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Paul Hovnanian P.E.
Spehro said:
You can also buy weld-on sprockets, for which the installation method
should be self-evident, at least in principle.
BTW, this isn't really an electronic design question.
It is now. Someone will have to post a schematic for a PWM controller
for an arc welder.
Spehro Pefhany
the keyed shaft.
Best regards,
Spehro Pefhany
Gary Tait
The sprokest ar jsut plain sprockets you weld onto a hub, the hup you
attach to your motor shaft.
For the likes of a bike, I'd think you need a keyed shaft and hub, and a
key.
Jon Slaughter
key.
and maybe some grease too?
