adding an AC level (~1V 3KHz Sinus) on a DC level (30 to 100 V) line
jsmith
hi
I will be appreciated with your comments and suggestions for adding an
AC
level (~1V 3KHz Sinus) on a DC level (30 to 100 V) line.
D from BC
hi
AC
Possibilities are:
1) A transistor common emitter amplifier
2) resistor network
3) transformer
4) RC circuit
5) summing amplifier
D from BC
John Fields
hi
AC
Assuming you mean "add" as in "algebraic summation":,
view in Courier:
..DC>---[L]--+----->DC+AC
.. [C]
..AC>--------+
petrus bitbyter
jsmith said:
hi
AC
What impedances are you talking about? Or you'd better tell something about
the application. Crucial for a usefull advice.
petrus bitbyter
jsmith
petrus bitbyter
impedance is about 1 MegaOhm
piezo driver
Eeyore
jsmith said:
hi
AC level (~1V 3KHz Sinus) on a DC level (30 to 100 V) line.
What impedance is the DC line ?
Graham
Michael A. Terrell
jsmith said:
hi
AC
Transformer couple the signal to the DC voltage. AKA "Modulation
transformer".
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Don Bowey
hi
AC
The most easy approach will be to use audio transformers having a split line
side. Put a non-polarized cap (1 or 2 mFd.) across the line-split leads of
the transformers (usually called the A and B leads). Put the dc voltage on
the A and B leads at one end of the line. Put the 3 kHz signal on the
primary of the transformer. At the other end of the line receive the dc on
the A and B leads, and the 3 kHz signal ar the transformer secondary.
Don
John Popelish
piezo driver
It may be a megohm at DC, but I'll bet a dollar it is lower
at 3kHz. What is the capacitance of the piezo device?
jsmith
at 3kHz. What is the capacitance of the piezo device?- Hide quoted text -
- Show quoted text -
I should measure capacitance of output long cabel and piezo, but it
will be less than 1uF
Phil Allison
"jsmith"
piezo driver
** Better not apply 100 volts DC direct to a piezo driver - it will blow
it up.
........ Phil
jsmith
"jsmith"
it up.
....... Phil
it is a piezo valve and its work range is up to 100V
Jan Panteltje
hi
AC
Small transformer secondary in series.
On its primary for example a 807 tube amp or a trans-sister.
petrus bitbyter
Ah, a piezo valve ranging 30-100Vdc and a "impedance" of about 1M. That's an
important piece of information. But, all piezo elements I'm aware of have a
capacitance too. That capacitance needs to be charged/discharged when
switching on/off *and* it is much lower an impedance then 1M for a 3kHz
sine. The line will have some impedance (mostly capacitive) too, highly
depending on the type and length of the wiring used. On the other side of
the line you will have a 30-100Vdc power source which also has an impedance.
Depending on the type it might even be a shortcut for the 3kHz sine. (Some
47uF smoothing capacitor for instance). That 3kHz sine source will also have
some (output) impedance I guess. So I still can't give an appropriate answer
to your question.
petrus bitbyter
John Popelish
It had better be. If the total capacitance were 1 uF, the
impedance at 3 kHz would be 53 ohms. It will make a lot of
difference to the driver if the total capacitance is 100 pF
or 1000 pF.
