adding components to pspice
K
Kenny
I would to know if it is possible to add components into pspice 9,2?
I would like to add the LM2587 for drawing a circuit and this part is not
included in pspice.
I looked on their web site and there does not seem to be a part list
database to add to the software.
So anyone know how or know of a more complete software that does simulation
thanks
ken
Jim Thompson
included in pspice.
thanks
ken
Are you using PSpice Schematics or OrCAD Capture? Student or full
version?
...Jim Thompson
K
Kenny
pspsice student version
so I guess I should change?
Don Pearce
included in pspice.
thanks
ken
PSpice allows you to add library components, which although a bit
fiddly is not really a problem. The simplest way is probably to get
hold of the necessary subcircuit from the device manufacturer and add
it with a text editor to one of the existing parts libraries. Then
borrow a symbol from another op-amp to make the connections.
d
Pearce Consulting
http://www.pearce.uk.com
K
Kevin Aylward
Yes. The SuperSpice demo allows far more components (30*25=750). It is
also much, much easier to use. Adding new models is a simle drag an
drop.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
Jim Thompson
[snip]
I'm uncertain, but I don't believe you can add parts to the student
version.
...Jim Thompson
K
Kenny
drop.
Do I have to build what I want from scratch or do I download some file ? if
so where ?
K
Activ8
so where ?
K
Component mfgs supply spice models/subcircuits and IIRC, you can
just drag and drop them from explorer into SS.
K
Kevin Aylward
Yes.
For .models symbols are automatically attached, for .subckts, it will
take you via the GUI to select an existing symbol when you try to place
the .subckts.
Kevin Aylward
[email protected]
Activ8
Yes.
the .subckts.
Kevin Aylward
totally painless and free as in free beer :)
K
Kenny
Do you have a link where I can download this then ?
thanks
Ken
legg
Ammm....never read signatures?
I believe the original enquiry was for models and subcircuit additions
to pspice.
Not SS.
If you want him to follow your line of thougfht, you will have to
explain the relationship between the two versions.
RL
K
Kevin Aylward
to pspice.
Yes. And you point would be?
Not SS.
Er.. It seemed pretty clear that the poster was asking where to download
SS.
..you will have to
Why?
Kevin Aylward
[email protected]
Charles Edmondson
[snip]
version.
...Jim Thompson
Sure you can! I wish he had said which one, though. The process is
different whether it is Schematics or Capture.
First, get a model for the part off the web somewhere. There are lots
of different sources. When in doubt, go to the manufacturer... :cool:
Give the file a .lib extension.
In Schematics, go to File/Edit Library. This starts the symbol editor.
Then, go to Part/Symbol wizard, choose From a model library, and
follow the instructions.
If you have Capture, start the PSpice Model Editor, and load the .lib
you created. Go to File/Create Capture Part, and it will create a part
for all the models in the library.
That's it, pretty much...
Jim Thompson
[snip]
version.
...Jim Thompson
Except that Capture SUCKS !-)
...Jim Thompson
