ADSL line filter
eltan
Hi all,
What is the best connection setup for ADSL line filter (micro) that come
with Netcomm modem?
Currently, two telephone, Phone 1 & Phone 2 is connected to a single
telephone line using double adaptor. The telephone line is then splited
again using double adaptor, one for Phone 2 and the other for the ADSL
modem.
Currently, the ADSL miroline filter is connected between the Phone 1 and
main line.
So, where do I connect the ADSL line filter?
Thanks in advance.
Martin
eltan said:
Hi all,
with Netcomm modem?
modem.
main line.
Thanks in advance.
You need another filter for the other phone, then put a filter before each
phone (but NOT before the modem!!)
Rob
Just remember its a clear line to the ADSL modem. The phones have a
filter before the phone. You may need a splitter to start - this is
clear to the modem and filter to the phone.
eltan
Okay, let me clearify my setup, there is only one active phone line
installed in my place. Two phones is connected to this active line, but
ADSL modem and Phone 2 is connected together to the splited active phone
line. I have only 1 line filter, but can get another one if required.
Diagram of setup....
____B__________ Phone 1
Active line _____A________/
\ ___D___ Phone
\___C__/
\________ Adsl
modem
Currently, the line filter is connected in position A
So, I'll need to install line filters at position B and D?
Thanks in advance.
K
Ken Taylor
No filter at A or D, just C and B. You'll notice that the filter (probably)
has an input, and two outputs marked 'phone' and 'ADSL'. The ADSL output
goes *only* to the ADSL modem.
Ken
Colin
B and D only need micro-filters.
Forget the extra socket if you have a splitter. It will be better to have
the line straight to the modem.
Chas
\ ___D___ Phone
Adsl
modem
Thanks in advance.
You need a filter at B and another at D. Remove the filter from A.
K
Ken Taylor
<sigh>..... like Colin and Chas said. My sleepy goof.
Ken
eltan
okay, I got it.
Thanks all.
eltan
\ ___D___ Phone
Adsl
modem
Thanks in advance.
Martin
eltan said:
okay, I got it.
Thanks all.
eltan
Of course your other option (which avoids the 2nd filter) would be:
_______________________ ADSL Modem
__________________/ _______ Phone 1
\__Filter__/
\_______ Phone 2
You just need to remember that the modem needs direct access to the phone
line but each phone needs to go thru a filter...
Michael
\ ___D___ Phone
Adsl
modem
Yes, and NOT at A
eltan
Thanks Martin, but the ADSL modem have to connect to the same line as phone
2 because its in the wall cavity.
Cheers
Rob
Cheers
This is where you use a splitter
eltan
thanks, problem solved when I connected the second mirofilter to phone 2.
By the way, the line to phone 2 is in the wall cavity.
cheers
eltan
Rob
and this is where you get a filter or splitter that can be hard wired.
