Advice Needed for Switching ~1000W Voltage Sources to Inverter
dwarnecke11
Feb 25, 2011
5
As part of my senior design project, I need to be able to switch between two 12V, ~90A sources as an input to a large 1100W inveter.  I'm planning on using a 93000uF 40VDC capacitor to support the load during the brief switchover time.
What method of switching should I use?  Mechanical relay, solid state relay, MOSFET, etc?  I need to switch a large amount of current at 12VDC as quickly as possible.  What about using a make-before-break configuration?
The two sources will be a large battery bank charged by wind and solar, and a gas turbine generator.
Hero999
Oct 28, 2007
2,433
Assuming the minimum operating voltage is 10V and the current is 100A, the 93,000
einstein0
Jun 25, 2011
11
Use a heavy rectifier (Dual 100 A). If necessary you could bypass them by using a bistable relay of an appropriate contacts rating.
I used this system in my campervan: 5 kWh/12V Batterybank & 140 Amp Alternator, supplying a 1000 W/12V inverter...
einstein0
