Advice needed on which portable oscilloscope is best
  • Thread starter Stephen Brett Davey
  • Start date
Stephen Brett Davey
I am looking at buying my first Portable Digital Oscilloscope.
It will need to have...
At least 2 isolated inputs.
Ch1 x Ch2 function to calculate Watts.
Bandwidth of 100MHz.
Record function.
8 or 12 bit vertical resolution.
FFT function.
I have looked at (but not used) the following...
Fluke 196C (2 inputs)
AEMC OX7104-C (4 inputs)
If anyone has used these or other similar oscilloscopes I would be
interested in hearing any good/bad comments you may have about them and
their use.
Rich Webb
Record function.
FFT function.
their use.
I have and am pretty happy with a 199C. Couple of comments:
The stock scope probes are fine but rather clunky. The tips require a
pretty good pull to remove them (straight pull, no twist or a "depress
this" button); they won't come off accidentally but you might think
you're having to pull *too* hard the first time you swap tips.
Reasonable battery life.
The FFT presentation is a bar graph (vertical line up to the data point)
rather than the more commonly seen line graph, with a line connecting
successive points. The bar graph is more correct (the FFT doesn't "know"
what's between the points) but a little harder to see.
Good selection of measurement options and trigger options.
The Flukeview software works well with the scope and the optically
isolated USB cable.
Vendor's forum at
<http://www.flukecommunity.com/forum...age=1&sort=lastpost&order=&pp=20&daysprune=-1>
Got mine at http://www.tequipment.net/. Have purchased a few things from
them over the years and generally found them to have good prices. No
complaints. (#disclaimer: just a satisfied customer, etc.)
