Advice on Equivalent transistors
Jpop
Jul 25, 2005
9
how will u know when a transistor u have replace from the project schematics will work? or how will u know if it is an equivalent of the previous transistor?
prateeksikka
Jun 19, 2004
736
some time spending and meddling up with data sheets and of course as audioguru said experience!
;D
Alun
Yes, locate the datasheet for the transistor the circuit request and find and equivalent transistor with similar chariteristics.
audioguru2
Apr 6, 2004
12,022
Hi Guys,
Most circuits use ordinary "general purpose" transistors.
If a circuit spec's a BC547 transistor then you can use a 2N3904 which is almost exactly the same (except their pin-out is reversed). ;D
Alun
But also note their main differences:
The collector-emmiter and collector base breakdown voltages vary between BC546 BC547 and 2N3904.
The gain varies between BC546A, B and C.
BC546xx only has a transition frequency of 100MHz, where 2N3904 has an FT of 300MHz.
The gain might not matter for a low gain device such as a buffer amplifier so it'll be alright to use a 2N3904 instead of a BC546C, but not in an audio amplifier which needs a high gain transistor.
The frequency won't matter in a simple light/dark switch so you could use a BC546 instead of a 2N3904, but not in a FM transmitter which needs a higher frequency transistor.
The trick is to understand what characteristics a circuit relies on to work properly - often it will say in the documentation, but check the voltage rating first then the current and maximum power dissipation ratings in circuits that use more power.
prateeksikka
Jun 19, 2004
736
behavior of the transistor to unexpected surge voltages is also important to know when designing
ante1
Jan 24, 2004
4,136
Hi anis,
Welcome to our forum.
Can you specify what kind of information you need?
