Advice sought for setting up a Mead model 300 "equatorialrefractor" telescope
Angel A.
My kid inherited this apparently ancient Meade 3.1-inch equatorial refractor
telescope, model 300, presumably in working order - but it doesn't work for us:
http://www4.picturepush.com/photo/a/13283857/img/13283857.jpg
We *think* we have all the parts; but we're not sure.
http://www5.picturepush.com/photo/a/13283853/img/13283853.jpg
Do you know of a decent forum where we can discuss the parts, setup, and
operation of this telescope for looking at the stars and moon?
Note: We can't even get the scope to work, at least not on the trees in the
distance:
http://www3.picturepush.com/photo/a/13283856/img/13283856.jpg
N
N_Cook
distance:
Meade queries have turned up on uk.sci.astronomy
W
William Sommerwerck
refractor telescope, model 300, presumably in working order -- but
it doesn't work for us.
I'm not being sarcastic -- in what way(s) do you expect it to work?
The vertical axis points to the North Pole, so a simple rotation of the
telescope is all that's needed to keep an object in view. That should get you
started.
Past that... I'd get a book on amateur astronomy (though I don't know of one
to recommend). You might also contact Meade to see if it has user manuals.
distance:
Beginning astronomy doesn't really lend itself to online tutoring.
The Meade model 300 is an older telescope; their 1972 catalog shows it
listing at $279. I'll let you translate that to 2013 dollars.
I'd suggest Googling 'Astronomy Club' and your city. You should be
able to meet up with someone capable of helping you. Alternatively,
Yahoo!! has the classictelescopes group. Or you can try
http://www.cloudynights.com/
PlainBill
O
Odysseus
us:
It looks reasonably complete, although in the first photo there's no
eyepiece inserted. The other photo shows several of those in the box;
start with the lowest power you have, which will be the one with the
*biggest* number (focal length) etched on it, probably around 20-25 mm.
In case you hadn't guessed, you focus with the paired metal knobs
between the "star diagonal" (the elbow below the eyepiece-holder) and
the main tube.
One critical element we can't see is the objective lens at the 'big
end', probably near the bottom of the large black cylinder (which I
guess is a baffle): this should be clean and unscratched. If you need to
clean it, be *very* careful not to damage the surfaces, which may be
coated. Handle it only by the edges, and use the most gentle treatment
possible, with a soft brush or lens-cloth, and only distilled water or a
residue-free lens-cleaning fluid that's safe for optical coatings.
Unless you live on the Equator, the first picture also has the 'scope
improperly oriented (the polar axis, the short shaft that's shown
roughly horizontal and parallel to the tube, should be elevated by an
angle equal to your latitude and locked there), but that makes no
difference to seeing things through it in the daytime.
Your best chance of finding someone with directly relevant experience or
practical tips will be at sci.astro.amateur. I'm taking the liberty of
cross-posting this message there as well. (And removing sci.astronomy,
which my news server doesn't carry.)
distance:
This is the finder-scope, an accessory that helps point the instrument.
There should be screw-holes in the main tube for attaching it, near the
eyepiece end. It's not strictly necessary, but can be useful, especially
when using medium-to-high power. Test it hand-held on the Moon: it might
not focus on anything nearer.
RichA
You know what I'd do? Sell the Meade to one of the collectors of old
scopes on Astromart or Cloudynights or Ebay and buy a new 6" Newtonian
reflector from Meade.
distance:
Try removing the black component that is located between the focuser's
drawtube and the diagonal. Then use your lowest power eyepiece (it
will have the highest number in "mm")and try aiming the 'scope at the
Moon. DO NOT AIM AT THE SUN!!
Do not attempt to clean the main lens at this time. Dirty lenses work
better than lenses that have been damaged by improper cleaning. The
lens should have a small dust cover that would have kept the lens
relatively clean, even despite the 'scope's possible age of three to
four decades. (I found this 'scope advertised in a '76 issue of Sky &
Telescope.)
The large component with the cord is probably a motor drive for the
scope. Be careful with whatever is in the jar. I don't know how the
coax accessory figures into any of this. :)
This should be an interesting scope, especially since it has an
equatorial mount with slow motion controls and possibly a clock drive.
