Aiwa MX-X3300M Amp/DSP problem
Dom
Hi - me again
I posted a couple of days ago with this problem and it was suggested I
checked the VFD soldering - done that and its all good. I still have the
same problem though - the Amp turns on and there is no display. After 15
minutes or so the display fades in slowly and if I quickly cycle the power
to the amp the controls appear to work again for a while. The same happens
with the radio VFD when connected (external Aiwa unit).
I've tested the VFD voltage from the regulator and when it is working I get
around 30 volts which appears within spec. When the display is dead I get
around 1.6 volts. This leads me to think that maybe the regulator for the
VFD has a problem.
Euras appears to have a fix for the problem but I dont have access to it
(symptoms are exactly the same - locked up control panel until the display
gets going as well).
Any ideas or schematics ? The VFD regulator circuit looks like it might have
got a little warm at some point but without schematics etc I'm a little
stuck (I'm a digital electronics engineer with limited analogue knowledge).
Thanks all again
Dom
JVC Dude
Its usually the electrolytics in that supply circuit that go dry. The Tr
does tend to run hot and discolour the board- usually without problem.
AW
Dom
Cheers TR - much appreciated :)
I'll have a probe around next time I've got some space on the workbench.
Is it just the ones in the VFD circuit I need to worry about or is this
problem more widespread across the board ?
Thanks again
Dom
