Akai plasma problem
max
I working on Akai plasma tv model PDP4298ED1.Tv working good in about 1
hour then picture start shaken and looks like scramble picture then
picture completely disappear and tv shuts off.Is anybody have a similar
problem with this model?What might be failed?Thanks
Sjouke Burry
Heat?
Put a ventilator pointing at the (open?) backside and see if
the problem re-appears.
b
change all the caps in the power supply secondary.
your problem is that Akai ceased to exist years ao, that is now just a
name badge stuck on the set. it could be made by anyone....
-B
max
-B
I checked all caps by ESR they all looks good.No leakage and value
matched with cap's sign.Do you think I still need replace all of them?
max
FOUND THE PROBLEM.The problem was not in PS board but in Logic
Board.Just removed each IC from the crib (there is 2 ICs in crib)clean
the contacts by contact cleaner put it back and BINGO.Tv starts working
like new.Thanks anywas for your suggestions.
