am fm car radio antenna trimmer
dudley
does anyone out there know if there is still a way to trim the
antenna
to the car radio?. I know that i'm showing my age with this
statement, but i'm having trouble with the fm stations fading in and
out as i travel down the road.i thought that there should be a trimmer
somewhere on the radio to tune the stations in stronger. its been a
long time since i have worked on radios ,so maybe there is not a way
to do it anymore. i have a 95 jeep
with am/fm and they both drift in and out.changed the antenna --no
help
so if anyone out there has an idea i would like to hear from you.
thanks dudley
Charles Schuler
antenna
help
My guess is that the radio is acting up.
g
My guess is that the FM antenna/radio may be working normally. AM radios
used to have a trimmer associated with the high ipmedance/low resistance
(very short compared to AM wavelength) antenna. FM antennas are at or
near a quarter wave and probably don't have any trimming as the real
part of their impedance is pretty large and matching is a bit easier.
Also, it is common for signals to vary with position as fast as once per
half/wavelength of distance, which may describe what you are experiencing.
How about comparing with the operation of other FM/antennas moving
through the same region, is yours working significantly differently from
others?
g
Charles Schuler
A snip from the original post: "am/fm and they both drift in and out"
Boris Mohar
antenna
help
thanks dudley
It has been a while. For AM there should be a trimmer hole somewhere close
to where the antenna cable enters the radio. The trick is to tune the radio
to a very weak station at low end of the band, somewhere between 550 and 600
KHz. Adjust the trimmer to best reception for that.
