Brian
- Jan 1, 1970
- 0
I've got a hotpoint washer / dryer that isn't rotating the
motor.
So heres an interesting puzzle for you
Anyone know how the motors are wired, or just know motores
well, and if the following analysis makes sense?
The motor says on it AC motor for electronic speed control,
1 phase. (904/1153/10). This is UK 240v.
I took the motor out and replaced the brushes, but its still
dead (the rest of the machine functions).
There are 7 pins going into the motor, with a 7 block connector
going in.
The wires going in are labeled 1-7 going left to right,
and all are white except pin 1 = sort of purple / lilac,
and pin 5 - red blue stripes.
I've stuck a multimeter on the motor, and can see
that pin 2 goes into one brush, pin 3 into the other.
When connected, there is about 7 ohms across the armature,
i.e. across pins 2-3.
Pins 1, 4- and 5 seem connected (~1 ohms) ..
Across pins 6-7 is 1.6k ohms.
The above measurement were all with the power off.
I put the mulitmeter into AC volt mode, stuck one pin on
earth (chassis), and sticking the machine into slow 'tumble' mode
checked the voltages which follow.
I'll put this into a little table to see if that helps:
THe table was done in notepad in courier new if the formatting
is a mess in your reader.
1 2 3 4 5 6 7
Purple White White White Red/Blue White White
->6,7 Armature Armature ->1,5 ->1,4 ->7(1k6) <-6 (1k6)
0V ~235V 0V 0 ~230V ~160V ~160V
Any ideas? Is the motor goosed? Control unit? Or does none
of this make sense to anyone?!
Thanks in advance.
Brian.
motor.
going in.
1 2 3 4 5 6 7
Thanks in advance.
Brian.
