Ger
- Jan 1, 1970
- 0
The PC program IPaNema reads NMEA sentences from one of the serial ports
(Com1-4), wraps these in UDP packets and delivers these to any UDP client.
The program can also act as an UDP client, receiving NMEA sentences over the
network as UDP packet, unpacks and outputs these to any of the serial
communications ports Com1-4.
Because the program can be used both as UDP server or client it gives the
user much flexibility in situations were there is a need to transmit NMEA
data over IP networks.
The program is freeware, and can be downloaded from www.sailsoft.nl.
For an application example see http://www.sailsoft.nl/ipanemaconfig.htm
