Eric R Snow
- Jan 1, 1970
- 0
Greetings Folks,
I have a video camera/transmitter unit that transmits in the 900 MHz
to 1200 MHz range according to the spec sheet. It currently has a
wire for the antenna that's 3.5 inches long. For optimum transmitting
doesn't the antenna length need to be a length that divides evenly
into wavelength? I will be enclosing the camera in a small plastic
waterproof enclosure with batteries and a light. Then it will be
lowered 70 feet down a 6 inch diameter iron pipe. It will be used to
inspect the well casing and pump as well as to watch the water as it
is being pumped. I want the best signal possible and was wondering how
long to make the antenna if the present one doesn't work. Right now,
in open air, a good signal is present at 100 feet. But I don't know
how well it will work when lowered down the iron pipe.
Thank You,
Eric R Snow
Thank You,
Eric R Snow
