Any xbox gurus out there ? need some help
moonlite
Can anyone explain why my clock menu on the screen is frozen ?? When I
turn the xbox on, I first get the xbox logo then it switches to my
clock menu and stays there. The clock is wrong and I can not change it
no matter what I do. I can't move away from it either. Loading a disc
doesn't change things. Is there a procedure to unlock this or at least
get the xbox working with the wrong time ? Thanks for any help.
Tony
James Sweet
Tony
Sounds like a motherboard problem, I'd start by looking for bulging
electrolytic capacitors in the power supply or mainboard, check the
voltages out of the power supply, or you could send it out for service.
I'm assuming it's long out of warranty.
gymz
Tony
gymz
Tony
Replace the coin battery on the motherboard this controls the clock
gymz
Michael Kennedy
If I remember right xboxes don't use a coin battery. They keep the time for
a short while with a capacitor.
- Mike
Jixter
Myself I'd maybe try leaving it unplugged for a few days, or possibly
discharging the cmos or removing a watch battery if it has a CRC2032. Also
try smashing the x button a million times as it boots up and maybe you can
get past the clock before the loop occurs.
Sounds like your XBOX could also have been hacked/exploited at some point in
time.
I found this info on the net..
1. Let it boot. Let your Xbox boot until it breaks out. Fonts will kick in a
set the time. (Doesnt work for everyone)
2. Plug your Xbox into an active computer network. After a couple of boots,
you should be out. (Doesn't work for everyone.)
4. Unplug Your DVD-Rom drive (I heard this works)
5. Put in a Audio CD (Also heard this works)
6. Unplug all controlers
7. If all else fails, then gain access to your Xbox HD, disable the fonts,
set the time and then turn them back on again
http://forums.xbox-scene.com/index.php?showtopic=200248&st=0
Jixter
Jixter
I almost forgot.. maybe post this question in microsoft.public.xbox
newsgroups might find some more xbox guru types..
Good luck.
Jixter
MikeZOD
It is a cap on main board located front left corner value very high
like 3f, it is probably leaking also, hard to find a replacement!
