Anyone Else Have Trouble Distinguishing Resistor Band Colors?
phaeton
Hi it's me again! 0_o
Do any of you have a hard time reading the color bands on resistors?
Well I am! When looking at the resistor itself:
1) I cannot see yellow bands against the beige resistor body at ALL.
This is less of a problem, as if i see no band, i can usually assume
it's yellow. White bands are very very faint.
2) Red and Orange. If one is right next to the other, sometimes i can
tell them apart, sometimes not. If there is only one or the other on a
resistor, i never can tell which it is.
3) Black, brown and violet. If black or violet is next to brown, i can
tell it's brown. If black or violet are next to each other, they both
look black. Brown by itself sometimes looks black, or occasionally
looks like red, depending on what is next to it.
What's funny, is that i'm not colorblind at all- anywhere else i don't
have this problem. In fact, i just recently saw an eye doctor and they
did the usual battery of "what number do you see in the dots" tests.
No problem. I was also fitted with glasses that correct my
astigmatism- everything is in focus now. I fiddled with electronics
somewhat about 10 years ago, and don't remember this issue.
I have one of those lil "resistor color code cheaters" from radio
shack's days of yore- turn the wheel and dial up the right colors, and
it'll show you the numbers. I don't have as much of a problem seeing
those colors, with the exception of black and violet (i distinguish
those by the numbers they bring up!).
All in all, when in doubt the DVOM comes out. I usually try to read
them first, and then measure them to see if i'm right. Sometimes i am,
sometimes i'm not.
I was suspecting my lighting- I haven't opened it up to look, but my
overhead light is probably a 100W incandescent. I took some resistors
of known values into the closet to view them under the flourescent
light. I expected the problem to be worse, but it's slightly better.
Not enough to help, but slightly better. I haven't tried sunlight yet-
it's been raining, snowing or cloudy for the last few weeks.
I might try a GE Reveal(tm) bulb:
http://www.gelighting.com/na/home_lighting/products/reveal_main.htm
Claimed to filter out "dulling yellows" and improve color clarity.
Dunno if it will help or hurt.
Anyone else have this issue, found a solution, or am i just not trying
hard enough? :p
Thanks for letting be dribble...
-jared
Rich Grise
hard enough? :p
Yeah - I have a lighted magnifier. :)
Cheers!
Rich
John Popelish
sometimes i'm not.
hard enough? :p
-jared
My ability to distinguish colors depends on the light source.
Sunlight best, Tungsten fair, compact fluorescents bad, sodium vapor
lights, forget it.
If you are using any kind of fluorescent, I suggest you look at its
reflection in a CD and see how its spectrum of color compares to
sunlight. Lots of shades are missing.
Thomas A. Horsley
hard enough? :p
Bright incandescent lights, take off my glasses, stick the resistor
about an inch away from my eye - maybe I can see then :).
(but be sure to check it in the multi-meter anyway before using it).
--email: [email protected] icbm: Delray Beach, FL |
<URL:http://home.att.net/~Tom.Horsley> Free Software and Politics <<==+
Steve J. Noll
hard enough? :p
I use only 1% resistors and find it impossible to read the colors
against that blue-ish background! I just use a good DVM.
Steve J. Noll | Ventura California
| The Used Equipment Dealer Directory:
| http://www.big-list.com
| The Peltier Device Information Site:
| http://www.peltier-info.com
John Larkin
sometimes i'm not.
hard enough? :p
-jared
The old Allen-Bradley composition resistors still look great. The
cheap carbon-film imports have very vague and inconsistant color
codes.
John
Bob Masta
hard enough? :p
At the lab where I used to work, we had exactly this problem,
especially with those blue-bodied 1% resistors. One of the
guys came up with the idea of switching to daylight balanced
fluorescents, which completely solved the problem. It made
the reds jump out from the browns. The only thing was it
made the whole lab seem like perpetual dawn light. Hard to
explain, but I found this unsettling after a few hours.
(Lab had no windows. Maybe I had become part Morlock.)
We eventually went back to mostly regular fluorescents,
with the daylight tubes only over the main parts drawers.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
phaeton
*whew*
I'm taking comfort in the fact that it's not just me. Thanks guys ;)
I picked up some of those GE Reveal(tm) bulbs, touted to hand out a
more balanced spectrum. It makes the room a little "whiter", but it
doesn't seem to make much difference reading the resistor bands. Oh
well...
I only spent a couple of hours under that light though, and near the
end of that timeframe, i was oddly starting to wonder if i would
eventually find the light somewhat "fatiguing". Correlation with Bob
Masta's story, perhaps?
I doubt that these are as daylight-ish as the flourescents though. I
may like to build a workbench with an overhead light with some small
daylight-spectrum flourescents. Oh yeah, it's that Time*Money/Room
problem again..
thx
-jared
Bob Masta
*whew*
well...
The daylight-balanced tubes we were using made the light
look "redder" to my eyes, not "whiter". It really was like the
light you see at dawn. I'll find out what model tubes we were
using and get back to you.
Bob Masta
D A Q A R T A
www.daqarta.com
