Eeyore
- Jan 1, 1970
- 0
If so there's a quick question I'd like to run by you.
Graham
Graham
Are you talking about "motorboating", which you get by biasing a singleEeyore said:If so there's a quick question I'd like to run by you.
Graham
Paul said:Are you talking about "motorboating", which you get by biasing a single
sided opamp audio circuit by just resistively dividing the power rail?
When I turn on a circuit I built that way it does sound like a zipper,
ie a run of pulses chirping upward in frequency.
Phil said:"Eeysore Red Hot Fuckwit "
** GIANT HUH ???????????
So - this demented, stuffed donkey wants someone to declare they already
know the answer to a question he has not yet posted.
Don't' play any such stupid games with this ridiculous TROLL.
Robert said:The first digital pots were rather bad; two sources (1) not many
steps = large step function in "analog" output and (2) large gate
capacitance coupling on/off step voltage to source/drain.
The newer ones are better, but i would use a scope synched with the
digital command pulse, tie each end of pot to resistor to ground where
resistance is equal to that of pot; scope probe to "tap" / "output".
Should give you an idea as to how good/bad that coupling is.
Guy said:Eeyore said:Anyone here familiar with so-called 'zipper noise' in audio
remote/automation level control applications ?
I am very familiar with it. The usual quick and dirty fixes are:
[1] Use lots of bits / high resolution.
[2] Slew-rate limit the fader so that is someone slams
the pot from bottom to top it doesn't skip too many steps.
This decreases zipper noise at the cost of increasing lag.
[3] If it's a gain applied to a analog su=ignal, Do the
actual gain switching at zero crossing. )Note: may conflict
with [2])
[3] If the entire signal chain is digital, de-zipper the
gain change by interpolating a bunch of small steps in software
between the larger steps from the fader hardware.
[4] Watch the gain structure so the system isn't using
the bottom 1% of the fader and following it with high gain
elsewhere.
BTW, if you are doing wolume control in a Windows program, read this:
http://blogs.msdn.com/larryosterman/archive/2005/06/16/429820.aspx
Glad to help any way I can...
Phil's there a mathematical treatment of the analysis of this noise that I
believe may be sufficient to 'prove' that a TI chip, the PGA2310 would not
be
suitable for automated / remote level control because of the limited
number of
steps (256) even though they are only 0.5dB each. I suspect it may still
produce zipper noise because the step size, although 0.5dB step despite
sounding small there are still only 256 of them (which is a classic number
for
producing zipper noise) and TI are I suspect foolishly mis-promoting it in
the
pro-audio market.
It would doubtless be fine for slow level changes but not fast ones.
It's expensive, as well.They should have reduced to step sizePhil's there a mathematical treatment of the analysis of this noise that I
believe may be sufficient to 'prove' that a TI chip, the PGA2310 would not be
suitable for automated / remote level control because of the limited number of
sounding small there are still only 256 of them (which is a classic number for
producing zipper noise) and TI are I suspect foolishly mis-promoting it in the
pro-audio market.
Graham
Thanks for that, I now have a nice taper on my laptop volume controlBTW, if you are doing wolume control in a Windows program, read this:
** Never heard timing the steps to coincide with zero crossings of the
signal ???
Yes.
Standard practice is all but low end AV gear.
Read the data sheet - dickhead.
Graham
Martin said:It's expensive, as well.They should have reduced to step size
Did something similar in the 80's, ended up with 2 multiplying dacs
with some soft FET switching, so you would update the off channel, do
a soft switch, say 1msec to the updated dac
Quite messy
I still like the alps motorised volume controls, (silly) but they
don't have a feedback/position sensor
Jan said:Hello Mr Rabbit
That what you call 'zipper noise', is familiar to me.
You find it for example in my sound blaster (EMU10) based sound card, when moving the slider.
Now a few interesting points:
This sound card also does zipper noise when silence, so you hear indeed
a zipper like noise when the slider moves.
So the design of the attenuator sucks (Hello Creative Labs).
So, first you should make sure changing attenuator steps (in hardware or software)
does not cause a signal by itself.
Second, and this is something I have only tested in a *light* related application,
perhaps you should, or could, switch amplitude only on the zero crossings of the audio
signal.
This would mean worst case for 20 Hz every 50 milli seconds,
So if the slider moved a lot in those 50 milli seconds, then you would have to move
a bit more at once, but during the zero crossing.
This does actually prevent higher harmonics switching noise.
I patent this solution hereby, and just because you insulted me and other people
in your previous rabbit posting, you own me 1000 Internet Credits for every
device you sell that uses my solution.
I am a bit surprised though that an audiophool genius like you cannot fix a simple
issue like that all by himself.
Well I don't know of you've ever herd of the AY3-something or otherIf so there's a quick question I'd like to run by you.
I've got a complete 6 channel eurocard PCB design using PGA2310'sI follow you and can quite believe it.
That's silly of them. In this case however the objective is to get a near perfectly
matched stereo (or multi-channel) volume control which is DC controlled (obviously
using an A-D) but I don't think the results will be adequate for pro-audio fades
etc. And it is *high-end* pro-audio.
Totally agree with your comment about the step size and it would have nice if they
soft switched in the PGA.
Graham
[email protected] said:I have read an article about "gating" the update of level with zero
crossings to eliminate it.
Jan said:Eeyore wrote in
It actually does solve the problem, and anyways 20Hz = 50ms period time, is a zero every 25 mS.
Especially for a fade that happens slowly that should pose no problems.
You could do some math and get slider speed and extrapolate / interpolate a bit too.
If you look for 'eliminating' well, as I have stated, I am no audiophool, and
think that most people will be more then satisfied with the zero crossing solution.
Looked up the PGA2310 datasheet, not bad.
Maybe you have to design your own circuit to work around those 16 ms.
Next time also specify what chip you are using before you ask, and try
reading its datasheet.
Rich said:Well I don't know of you've ever herd of the AY3-something or other
sound generator; it had a tone generator and a 4-bit digital attenuator.
You could program it to make a "beep" sound; that was trivially easy.
But once I wrote a little driver that would simulate a "ding" by doing the
"beep" and stepping the attenuator on that standard e^-t time constant
thing; but with only 16 steps, it sounded a little raggedy. That could
be "zipper noise", depending on what's caught in your zipper! ;-D
Is that what you're talking about?
Martin said:I've got a complete 6 channel eurocard PCB design using PGA2310's
somewhere, (I never finished the software though).
There was a wolfson chip now obselete, which looked stunning compared
to the TI/BB offering wm 8816? I think someone bought the design from
wolfson
back to my DAC version, (it was for a analogue eq with recall) I think
I had some sucess by putting a little sample and hold that was
switched in during the transition that reduced the glitches by about
30dB, basically a LPF.
Arn't the THAT VCA's good enough?
