Are there smoke alarms rated for unfinished attic?
Hi
I have a 3 story house in Raleigh, NC. THe 3rd floor is unfinished
attic space with a regular staircase walkup i.e parts of that attic
can be finished to give us an extra room with bath and closet.
Currently there is an outlet installed to add a smoke alarm. The
outlet seems to connected to other smoke alarms in the finished space
of the house. I was thinking of adding additional smoke alarm there to
get an alarm if a lightning strike caused fire in the attic.
I did call the smoke alarm manufacturer - Firex - but they said they
did not have any smoke alarms rated for attic space use.
Are there smoke alarms rated for the attic? I would like any smoke or
fire in the attic to trigger the other smoke alarms in the house.
Are there alternate solutions ?
Robert L Bass
Hi Bob,
Smoke detectors are not used in unfinished attics. They need to be in a controlled environment where extreme heat, cold, humidity
and (most important) dust are minimized. The usual approach is to install rate-of-rise heat sensors in the attic. These are only
to be used as accessories to a fire or combined fire/burglar alarm system. They are *not* life safety devices though.
BTW, there is one System Sensor (brand we sell online) smoke detector that is designed for dusty environments. It wouldn't be
appropriate for an attic though, due to heat limitations and frequent service it requires. I mention it because it may be of
interest for other difficult locations. Following is the spec:
System Sensor FTX-P1 Filtrex Intelligent Photoelectric Smoke Detector
System Sensor Filtrex Smoke Detector provides early warning smoke detection in difficult environments where traditional smoke
detectors are not practical. Filtrex provides protection in dirty, dusty environments that tend to cause false alarms with standard
smoke detectors.
Operation:
Using a small air intake fan and a high density replaceable filter, air and smoke are drawn into a photoelectric sensing chamber
while airborne particulate and water spray are removed. When the filter becomes too clogged to draw adequate air into the sensing
chamber, power is cut from the detector, causing a trouble signal at the fire alarm control panel. When the filter is replaced,
power-up is automatic.
Features:
a.. Intelligent communications
b.. High density filter removes particulate down to 32 microns
c.. Air delivery system is separately powered and fully supervised
d.. Filter is easily field replaceable
e.. Resistant to water spray in applications where occasional hose-down cleaning is performed
f.. Optional remote LED accessory
g.. Rotary decade address switches
h.. Compatible with 200 and 500 Series products' protocol
i.. No modification required to panels compatible with System Sensor intelligent photoelectric smoke detectors
Applications: a.. Animal research facilities
b.. Institutional laundry facilities
c.. Amusement parks
d.. Zoos
a.. Performance theatres
b.. Loading docks
c.. Paper mills
d.. Textile mills
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Jim
Hi
Hi Bob
Without trying to sell you something, the answer is that there aren't
any smoke detectors that are rated for use in an unfinised attic. Rate
of rise heat detectors are recommended.
With regard to Robert Bass, There are some good people and some bad
people. This person has a bad reputation here and elswhere in Usenet.
Before you consider buying anything from him, please take a look at
his terrible BBB report. He'll tell you anything and act as if he's
your best friend, just to get you to order from his website. He gets
no respect from anyone who frequents this Newsgroup.
http://www.bbbwestflorida.org/commonreport.html?bid=41001663
F
Frank Olson
Hi
I would suggest going with fixed temperature heat detectors. You can
interconnect them to a standard Firex 428 smoke alarm quite easily since
the orange wire is 120VAC. If you have multiple smoke alarms they must
all be of the same type (Firex 428's for instance) and capable of
switching 120VAC (not the low voltage DC interconnect that many common
smoke alarms employ).
The best solution is to go with a burglar panel that's UL (or ULC)
listed for fire & burg, and use supervised heat and smoke alarms. That
may not be in your budget at this time, but it's definitely worthwhile
exploring if your family means as much to you as mine means to me.
Similar threads
Replies
18
3K
Jasen Betts
Replies
10
2K
Franc Zabkar
F
H
Replies
8
2K
Lee Babcock
